Transit Euro 4 fwd vnt electronic turbo
Postby loot » Sun Feb 28, 2021 9:00 pm
As above mines a 2.2 56 plate mk7 fwd euro 4 and 130ps but I believe that the 130 and 140 are the same.
Ideally I'm looking as cheap as possible please.
Thanks.
07 350 170ps
Ids map here
loot
Re: Transit Euro 4 fwd vnt electronic turbo
Postby andz327 » Sun Feb 28, 2021 11:44 pm
Whats fooked in it mr loot
ANDZ
andz327
Postby andz327 » Mon Mar 01, 2021 4:07 am
I've a spare/original actuator from when i changed auld Bettsie to a 140 turbo, and think I've still got the original 130 turbo itself as was going to refurb......
Mate it was still working and only changed it basically coz i had the 140 sitting , if i parked up and had engine running for heat for couple of hours (before i got the covid heater) then went to pull away it was a bit smokey but smoke cleared up after a minute but was still a goer and was ok driving aboot, if your stuck yer welcome to it mucker
ANDZ
andz327
Postby andz327 » Mon Mar 01, 2021 5:33 pm
IT'S THERE IF YOU WANT IT
TELL ME IF YOU DON'T AND I'LL PUT AWAY AGAINImage
ANDZ
andz327
Postby andz327 » Mon Mar 01, 2021 5:34 pm
andz327 wrote:Whats fooked in it mr loot
ANDZ
loot wrote:As above mines a 2.2 56 plate mk7 fwd euro 4 and 130ps but I believe that the 130 and 140 are the same.
Thanks.
andz327 wrote:I've a spare/original actuator from when i changed auld Bettsie to a 140 turbo, and think I've still got the original 130 turbo itself as was going to refurb......
ANDZ
andz327 wrote:IT'S THERE IF YOU WANT IT
ANDZ
ANDZ
andz327
Postby loot » Mon Mar 01, 2021 5:37 pm
Is it the whole turbo?
Mine is loose and a bit worn and the ring isn't engaging with the rod, it has like a metal number 8 shape that sits in a number 8 hole in the ring and twists, mine slides over the top so will boost or not boost.
Do you think yours is worn seals?
If it is working and not really wobbly I'd like to buy it.
Let me know how much and postage to Wales, will be 20 quid royal mail :shock:
Cheers. 8)
07 350 170ps
Ids map here
loot
Postby loot » Mon Mar 01, 2021 5:40 pm
Mine is unplugged at the minute but trying to speed up it's very tedious, and this old woman in a zephyr keeps flipping me the bird at the lights before overtaking me at 9mph :lol:
07 350 170ps
Ids map here
loot
Postby andz327 » Tue Mar 02, 2021 2:18 am
Mate you can have it for nowt if it's gonna help you oot mucker, it was still moving auld B 100mph+ before taking it off....... Genuine guarenteed mileage tae
ANDZ
andz327
Postby andz327 » Tue Mar 02, 2021 4:41 am
London turbo Image
ANDZ
andz327
Postby loot » Tue Mar 02, 2021 9:08 am
Nice 1 Andz, details sent and Swiss bank notified 8)
I was going to replace the nozzle ring but the core needs doing and I damaged the seal removing it from the body and the actuator gears are worn so decided to replace. I can get a turbo for 264 that is reconned but need to send mine to them so that's another 20 quid.
And with this combo bleeding me dry I'm reluctant just now :cry:
Plus the orangery needs doing for vansitmania :lol:
Anyway, top man cheers. 8)
07 350 170ps
Ids map here
loot
Postby Altransit » Tue Mar 02, 2021 9:56 am
If it's heavier than 2kg, or bigger than a RM "small parcel" then send it using parcel 2 go, it will be a lot cheaper :idea:
Postby loot » Tue Mar 02, 2021 10:40 am
Thanks Al, i know I paid 20 quid to rm my knackered turbo back to ebay :(
07 350 170ps
Ids map here
loot
Postby andz327 » Fri Mar 05, 2021 2:12 am
Mate i was at Telford today (with have yer turbskie onboard) and was on surprise attack mode to get it to you..... got halfway to to LOOTS LAIR but got sent an MOD job back at Telford that was going to INVERNESS so I'll probably price postage the morra/today and give you a shout..... Plan nearly worked
ANDZ
andz327
Postby loot » Fri Mar 05, 2021 9:46 am
Oh no, I hope you haven't wasted fuel and time on me lol. I'll make sure you're reimbursed :P
07 350 170ps
Ids map here
loot
Postby andz327 » Fri Mar 05, 2021 10:51 am
Do uou need the electronic part??
ANDZ
andz327
