Had a good few hours on the van again today, fitted the boost pipe that I was waiting for and finished off the last bits of wiring for the transit water temp sensor and oil pressure sensor.
Also fitted the vac pipe I'd made up using ½ transit and ½ vw.
Had her running up to temp and and got a few test drives up and down the street, was able to put my foot down a little and was pleasantly surprised at how pokey it was!
2nd test run saw a boostpipe blow off so just shows its producing boost
I do have a few snags to address later down the line, it seems a have a weeping crank seal and a noisy thrust bearing (was a reused 2nd hand part
) so will sort both these at the same time.
Boost and egt guages fitted, dash reassembled, radio fitted, small brackets I'd made up to support the grill fitted and all of the crap I'd collected in the boot removed too.
Shes desperate for a good wash after being stood for nearly 18mths but is all but ready for an mot, just a new set of wipers as the others have perished due to being sat.
1999 mk5 tourneo (previously jagvan, now Vw PD powered)
2000 mk5 with a jaguar twist
(now dead but will live on)
1996 disco 300tdi 1.2 offroad toy
