Mk1 transit gutter rot
Postby blue74 » Thu Apr 01, 2021 12:34 pm
Good evening gents, I have finally purchased my first transit and need to replace the roof gutter around the rear of the van. The factory gutter is not a simple folded section and has a curve up the side and swage along the bottom. Does anyone have any tips on how they have successfully remade the gutter section to include these features?
Any pictures of how you have done the repair would be great.
TIA
blue74
Re: Mk1 transit gutter rot
Postby Ralph.9 » Fri Apr 02, 2021 6:59 am
I might have some used gutter sections, when I replaced mine I had to remove the roof skin.
Ralph.9
Postby blue74 » Thu Apr 08, 2021 5:13 am
Thanks Ralph, I wondered if that may be the best option. Looks like I have a lot of welding to do.
blue74
Postby NogE » Sat Jul 17, 2021 7:49 pm
The cutouts on the gutters....gutter drain holes..was there a repair section with them in ever made?..my gutters are minus them...is there a way of making them....trimming them in..
NogE
Postby blue74 » Sun Jul 18, 2021 11:32 am
Do you have any pictures of what it should look like?
blue74
Postby Neil » Mon Jul 19, 2021 6:50 am
NogE wrote:The cutouts on the gutters....gutter drain holes..was there a repair section with them in ever made?..my gutters are minus them...is there a way of making them....trimming them in..
ive seen a lot of vans with the drain holes gone / filled in,,, on a light coloured van after a lot of rain it would leave a dirty stain where the water runs down the back quarters where the holes were
Neil v6
Neil
Postby NogE » Wed Jul 28, 2021 6:30 pm
The drain holes at rear... is there a way to fabricate them...
NogE
Postby blue74 » Thu Jul 29, 2021 11:17 am
NogE wrote:The drain holes at rear... is there a way to fabricate them...
Can you find a picture of what they should look like to give us an idea?
blue74
Postby NogE » Thu Aug 05, 2021 4:30 pm
Hi blue.... Conrod has posted me pics on another forum...I'm having trouble replying here for some reason
NogE
Ah ha..looks ok today...I'll try get them up asap
NogE
Postby NogE » Fri Aug 06, 2021 8:14 am
Hope this pic shows blue...
NogE
Postby NogE » Fri Aug 06, 2021 4:41 pm
So from what I can gather...some had them and others didn't...a friends mk2 don't hv em.
NogE
Postby blue74 » Wed Aug 11, 2021 6:32 am
The easiest way I can see would be to make up the gutter drain out of a piece of sheet metal then cut out a slot from the drip rail and weld the new piece in.
blue74
Postby NogE » Fri Aug 13, 2021 6:23 pm
I was thinking of this...had a discussion with Conrad here....maybe try do the fabrication in place....abit harder tho..
NogE
Postby Neil » Fri Aug 13, 2021 6:34 pm
multitool a small slot ??
Neil v6
Neil
Return to Mk 1 & 2
cron
