MartNewm wrote:. There is what looks like a ceramic ballast resistor by the headlamp, is that for the sidelight headlamp glow when the engine is on?
Noctule wrote:The ballast resistor is for the blower in the cab.
Like Matt has said, it's actually not bad at all. I've had mk5s in worse condition, repaired some that have been much worse, and it's like new compared to some mk6s I've seen.
80’s Fords = rust rust rustMartNewm wrote:Been busy, done loads and have nothing really to show for it. The floor is now solid again, that was a bit more than I imagined it would be, probably should have replaced the whole thing! Exposed a tin foil front crossmember that I have ordered a replacement for. Took out the long since dead alarm/immobiliser that was present and tidied up years of botched wiring jobs. I did have a bonus find though, some nice little Alpine component speakers in the footwell. I’ve no doubt they’re the most powerful thing about the whole van. Had a random experience of the headlight glass falling out, not broken but the reflectors are a bit manly, might replace them yet. But on the whole, getting there and reminding myself what a 80’s Ford was all about.
blue estate wrote:80’s Fords = rust rust rust
roark91 wrote:Good to know that you were able to fix the floor.
