Mk)8 minibus conversion.
Postby JamesHow » Tue May 11, 2021 7:19 am
Hi just brought a mk8 15 seater minibus for converting.
Not a full conversion but a day van conversion with the plastics remaining.
Do I need to insulate behind the plastics?
Should I paint the underside as transits are prone to rust?
Many more questions to follow.
This is my 2nd conversion after a movano last summer which died at Christmas.
Cheers James
JamesHow
Re: Mk)8 minibus conversion.
Postby JamesHow » Fri May 14, 2021 6:45 pm
Van is great drives nice - car like really, plenty of power to get over the Yorkshire dales.
Stealing wheel is small! A bit sensitive compared to the master and sprinters I have driven.
Filled up at the garage and read the weight plate 4100kg! Help!! That's not what I thought it was!
Going to have to get it downplayed svtech charge £144.
Doh needs must!
Cheers James
JamesHow
Postby JamesHow » Sun May 16, 2021 10:27 am
Stripped out the seats today anyone want 3 doubles and 4 singles!!
Floor was grubby so scrubbed it, needs another going over!
What's the box at the rear left with vents in see pic????
Then picked up some 4x2 cls and a sheet if plywood.
I envisioned using the cup holders but there is only one in the right area.
So I used that as middle support and the other one simply rests on the ledge. Seems strong enough - a naked van pics shows there is a large steel beam under it.
Ply went on top with 6 large panhead screws securing.
So I can easily revert it to a van for work duties.
I could cut the middle piece in half for extra manvoverability but 3 more screws.
Loo enclosure and kitchen units to follow. The seat lugs will probably suit champing them down.
Pics here
https://www.motorhomefun.co.uk/forum/th ... 947/page-2
Cheers James
JamesHow
Postby dumper » Sun May 16, 2021 2:16 pm
Rear aircon I removed mine had the pipes blocked off as it was taking up room in the storage area and making anything in there damp
Postby JamesHow » Sat May 22, 2021 10:06 pm
Hi just an update I've made a kitchen unit 12mm plywood.
Basic but functional .
See link above, I must learn to post pics on here.
Cheers James
JamesHow
cron
