Well done DD, I shall look forward to seeing what you do to herdirtydog wrote:Been waiting for a delivery for most of the day so took tango to the tyre/exhaust place across the road from the job I'm on to get the air con gassed up, unfortunately there's a leak in the system somewhere
So then I took it up the garage for the jet wash, spent about 20 minutes in there giving it a good clean. Could do with some more time but I ran out of coins
I phoned a breakdoon wagon for mine does that countned wrote:About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres
andz327 wrote:I phoned a breakdoon wagon for mine does that countned wrote:About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres
Sent from my SM-G975F using Tapatalk
Fuel pipe holed....... high pressure metal pipe from pump to railned wrote:andz327 wrote:I phoned a breakdoon wagon for mine does that countned wrote:About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres
Oh dear, not the oil cooler again surely, can’t be no enough oil on the headlight, wing, bonnet
Fuel pipe holed....... high pressure metal pipe from pump to railandz327 wrote:ned wrote:I phoned a breakdoon wagon for mine does that countandz327"quote="ned wrote:About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres
Fuel pipe holed....... high pressure metal pipe from pump to railned wrote:andz327 wrote:I phoned a breakdoon wagon for mine does that countned wrote:[quote="andz327"quote="ned"]About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres
andz327 wrote:All sorted and back on the road
