Keef wrote:Check the cambelt hasn't stripped or snapped.
dumper wrote:Possible the injection pump is breaking up inside and jamming the stop open ( had loads of pump failures when we went to low sulphur diesel first the stop started jamming and not long after need new pump )and now possibly stuck closed or it’s just packed up .with ignition switch on try unplugging the feed wire on and off and listen if you can hear it click
Altransit wrote:Keef wrote:Check the cambelt hasn't stripped or snapped.
Likely stripped around the bottom pulley where there are fewer teeth, it's about the only reason that a Di just randomly stops
Altransit wrote:It's always possible, it's only about £20 for a new switch, and a few minutes to fit it
Mattyone wrote:Altransit wrote:Keef wrote:Check the cambelt hasn't stripped or snapped.
Exactly what you said stripped the teeth round the bottom pully, bent two push rods, is there a reason for stripping teeth there, is it like you said few teeth on the bottom pully.
Keef wrote:That pulley is for the camshaft so If you've taken the rocker shaft off then it probably will spin fairly freely.
There's a guide here viewtopic.php?f=18&t=56801
Users browsing this forum: Google [Bot], troyscully
