Transit Connect 230 2008 starting problems
Postby dogwalker64 » Tue Jun 08, 2021 9:59 am
Hi. Im hoping someone may be able to help or point me in the right direction.
Im have random start up issues with my connect . Sometimes its starts on the button but every 5 or 8 starts its will turnover very slowly like
the battery is flat. I turn the key back and try again and it fires up like normally. I had a new clutch fitted about 350 miles/4 weeks ago but its only started doing this over the last 5 days. The battery is about 10m old. I did put it on charge and it seems fine,When its running its runs along fine
Any help gratefully received
dogwalker64
Re: Transit Connect 230 2008 starting problems
Postby Kenton » Tue Jun 08, 2021 11:06 pm
Could be the starter motor getting tired :?: They are not that expensive to replace, and not difficult to access; from the front,
right behind the lower part of the radiator. Maybe take it off and test it with a 12v feed direct from the battery. Listen and see if it sounds unnecessarily noisy or 'dry'. If it looks like it has seen better days, then look for a good aftermarket replacement from one of the motor factors. :) May not be the fix, but an inexpensive elimination of a possible cause.
K.
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Mondeo Inner Door handles & vents
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby dogwalker64 » Thu Jun 10, 2021 10:03 pm
Thank you for the help. I’ll give it a try.
dogwalker64
Postby dogwalker64 » Tue Jun 15, 2021 4:52 pm
Just to update. Changed the starter motor and havent had the problem for 2 days now.fingers crossed
dogwalker64
Postby Kenton » Tue Jun 15, 2021 11:02 pm
That's great :D Thanks for updating the thread and letting us know. Glad you are sorted, and come back to the forum soon mate 8)
ST 17" alloys
Focus ST170 seats
Sport spoiler
Blacked h/lights
Side bars
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby Boghopper » Thu Apr 11, 2024 3:56 pm
I have the exact same problem on my '56 Connect and am going down the starter motor route. I have compared the voltages on my Tourneo 1.8 with the Connect 1.8. I have just fitted a new battery and alternator on the Tourneo, but the Connect battery and alternator are nearly identical readings, even under cranking load. The battery and alternator were put in at the end of 2017, on the Connect. The starter is the original and is now 18 years old with 80,000 miles of cranking under its belt.
Will fit a new one and let it be known if the intermmitent and lazy crank vanishes. I have noticed that you can purchase the brushes and holders for the Motorcraft starters, so I will get one of those as well. In recent years I have been keeping all my old parts and refurbishing them as much as possible.
Boghopper
Postby Boghopper » Mon Apr 22, 2024 9:33 am
Yes, changed the starter over; managed to get a refurbed Ford item: RE2T14-11000-CC. Anyway, that's got rid of the lazy starting; it's almost aggresive the manner in which it starts now.
Boghopper
Postby Boghopper » Wed Jun 05, 2024 10:46 pm
Just to add; I have had this van since early 2009, when it still had six months warranty on it. Well, the clock, on the radio has never kept the correct date. It always kept the time, but not the date. It would gradually start falling behind with the days and you would have to keep on re-adjusting it. Anyway, since changing the starter motor the date does not fall behind anymore, don't know why, but there it is. Another piece of worthless trivia.
Boghopper
