My Mk2 100 Panel Van
Postby Pinto » Sun Mar 13, 2005 1:29 pm
Just a few shots of the old girl :)
She was orginally a British gas special order, fitted with an external (110V ?) power supply in the rear quarter. It was then sold on to a shopkeeper who used her as a mobile shop for a short while, then parked her up for about 8 years. She had only 58,000 miles from new on her when I took ownership.
as you can see, she had some extensive bodywork repairs due to standing outside for nearly a decade ! These included new arches, wings, bonnet, front crossmember and inner rear quarters...
Current colour is a fetching shade of John Deere Green, but im planning something new shortly, as Im none too keen on it tbh :)
Current thinking is to go with Garland green (colour of the front in the first photo) or Flambeau Red metallic
Pinto
Postby madmark » Sun Mar 13, 2005 1:32 pm
she looks very well there mate !
Postby FredTransit » Sun Mar 13, 2005 2:24 pm
Ah bless! Maybe I missed something, but is she a phase1 or pahse2? Hard to tell without seeing the front or rear lights.
FredTransit
Mk2 Trannyist
Postby Luke » Sun Mar 13, 2005 2:27 pm
Yep looking good :D
all that paint to decide you dont like it :shock:
Ill be a transit spotter now fred! and guess thats a phase 1 - no holes for the longer rear bumper corners!!
Postby Pinto » Sun Mar 13, 2005 2:36 pm
Nope, she's a phase 2 on the 85 'C plate :)
The rear bumper mount holes were welded up in a moment of miscommunication :lol:
At current, she has phase 1 bumpers on her (as I had a set), so its not really a problem.
Luke wrote:all that paint to decide you dont like it :shock:
well, it seemed like a good idea at the time :lol: - but its not too bad - paint costs about £15 a litre from the right sources and it takes about 3 litres or so to paint, being a SWB.
Pinto
Postby FredTransit » Sun Mar 13, 2005 8:18 pm
Pinto wrote:Nope, she's a phase 2 on the 85 'C plate :)
Was that "just weld up all the holes and I will see you later"...............? :lol:
FredTransit
Mk2 Trannyist
Postby Gunslinger » Sun Apr 03, 2005 2:39 pm
those doors look good :wink:
as for the back panel ... no problem, just pump it full of expanding foam and ignore it, it should never give you any more problems :p
Gunslinger
Postby FredTransit » Sun Apr 03, 2005 5:30 pm
Gunslinger wrote:those doors look good :wink:
Expanding foam, be careful of this stuff, our welder says it goes up at a minutes notice, especially if you are welding and don't know it's there!!! :lol:
FredTransit
Mk2 Trannyist
Postby Gunslinger » Sun Apr 03, 2005 5:47 pm
oh yeah ... it will do that alright, you can get fire retardant stuff (it aint that good though) ..... but if, like my van a lot of the rot problems are coming from the inside of the box sections, after you have replaced / patched all the knackered bits, there is nothing better really for removing all of those voids that cause the problems than this stuff.
if you get it all fixed first, then do the box sections with it, it will expand into all the little nooks and crannies, it sticks like sh*t to a shovel, and if sealed properly at the inject/overspill areas it will never let water in, and will prevent condesation/damp forming in the box sections. Bear in mind it also reacts to water in the atmosphere on expanding so it will in some way remove existing dampness from inside box sections
Tat lot said .... your welder is dead right, if you ever need to repair a section filled with this stuff, it will make the job twice as hard ..... however if your needing to do this then you did something wrong in the first place :P
Gunslinger
Postby bortaf » Sun Jan 22, 2006 12:21 am
Ford used to inject that foam into rally car shells to strengthen them :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby FredTransit » Sun Jan 22, 2006 12:31 pm
bortaf wrote:Ford used to inject that foam into rally car shells to strengthen them :D
Did they ever expect to weld em though? :lol:
FredTransit
Mk2 Trannyist
Postby Pinto » Sun Jan 22, 2006 1:40 pm
"Someone go and get me the HobbyMIG and som Isopon.... " :lol:
Pinto
Postby FredTransit » Mon Jan 23, 2006 1:21 am
Ouch.
FredTransit
Mk2 Trannyist
