Can I Retrofit
Can I Retrofit
Postby need4speed » Tue Nov 23, 2021 10:29 am
I have a cattle-class custom with only 1 poxy little 12v6w bulb lighting the whole front cab. Would wiring etc already be in place for me to retro-fit this?
need4speed
Re: Can I Retrofit
Postby need4speed » Tue Nov 23, 2021 4:23 pm
Meant to add. I really need extra light in cab as I’m a courier and at this time of year I’m struggling to see with the 1 miserable light at rear of cab ceiling..
need4speed
Re: Can I Retrofit
Postby need4speed » Wed Nov 24, 2021 6:44 pm
Anyone?
need4speed
Re: Can I Retrofit
Postby Altransit » Wed Nov 24, 2021 7:11 pm
Do you not have two front cab lights in the Custom?
I fitted (soldered) some small LED panels in to my Mk7 cab lights, because LED bulbs that fit the holders, are the wrong polarity for these interior lights.
Re: Can I Retrofit
Postby need4speed » Wed Nov 24, 2021 8:35 pm
I think the higher spec models have 2. 1 at rear of ceiling just in front of bulkhead and another that’s combined with a storage bin at front of ceiling next to mirror. Just like I pictured.
However my cattle class spec van only has the 1 at rear of ceiling. 1 poxy 12v6w bulb for whole of cab. It’s dire mate.
If it’s possible for me to retrofit that storage bin/light I can add an led bulb to both lights and hopefully that will be adequate..
need4speed
Re: Can I Retrofit
Postby M3Stig » Fri Nov 26, 2021 7:32 pm
if it was me i would just get a 12v LED light bar double side it to the plastic of roof lining and then hard wire it into the bulb housing
M3Stig
Return to Transit Custom
