Someone must know the answer to this hopefully easy question
I remove the fuel feed pipe coming from the filter AND also remove the return feed that would go back to the filter
I turn on ignition and fuel is being pumped out of both pipes
It's a new OE filter and OE housing and brand new OE pipes (the old pipes had exactly the same issue)
Surely can't be right that fuel is being pumped up the return pipe as well as the main feed pipe? Or am I missing something?
Al
