Ignition timing slipped
Postby Ellwood » Thu Mar 03, 2022 6:36 pm
I found a weird fault today. Last week my mk1 essex started, but was running as rough as a dog. After a fair bit of faultfinding i found two faults.
The rotor arm resistor had burnt out.
Also whatever powers the distributor rotor must have slipped 180 degrees. Simple fix was to swap over the plug leads to opposite sides of where they sat before.
I experienced this same problem 40 years ago on a TR7. Cant understand how it happens.... Maybe a poltergeist???
Ellwood
Re: Ignition timing slipped
Postby metalworker0 » Sat Mar 05, 2022 11:30 am
I know the coil polarity can become reversed ..don't suppose that could have anything to do with it .
Postby fordv8racing » Tue Mar 08, 2022 9:27 pm
if your talking about the essex v6 use to be a common problem with wear on the fibre timming wheels
fordv8racing
Postby Chug » Tue Mar 08, 2022 11:12 pm
yeah maybe time to pull the dizzy out and have a look see
Chug
Postby DougT » Sat Mar 12, 2022 8:33 pm
Presume you changed the rotor arm after you found the faulty resistor. But did you find it to be 180 deg out before or after you changed the rotor arm ?
Just wondering if the locating lug on the new rotor arm was in the opposite orientation to the original.
Doug
DougT
Postby Ellwood » Sun Mar 13, 2022 11:12 am
I will check out that rotor.. Praps the replacement had the locator pin in wrong side.
Last time years ago i pulled out the dizzy, the hexy rod dropped down into the sump... Nightmare to get it out.
Ellwood
Return to Mk 1 & 2
