MK5 Bosch Conversion Australia
Postby Fat80y » Sat Feb 26, 2022 10:37 pm
Hi All,
Hoping someone can help me out - I live near Newcastle Australia, and we only got epic transits over here.
Need an accelerator pedal, and the the rear mounting bracket for epic to bosch conversion.
I already have a pump, and it appears accelerator cables are still available on ebay.
Not looking for charity, happy to pay market price and postage, as my only alternative is to remove parts from my existing conversion and have copies made!
Can anyone assist?
Fat80y
Re: MK5 Bosch Conversion Australia
Postby MinorMatt » Mon Feb 28, 2022 1:08 pm
When you say rear bracket... there are 2 parts to it, one that bolts directly to the back of the pump, and the other joins that to the block - which part do you mean?
I definately have new/genuine lower brackets and probably have a pedal too
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Fat80y » Thu Mar 03, 2022 6:46 am
Hi Matt,
Sorry I forgot there was two brackets. I originally assumed I just needed the small one that bolts to the block.
I'll double check tomorrow (Friday) if I need the large bracket that bolts to the pump as well...
Please keep a pedal aside for me, and if you can source a cable I'd like to get from you as well.
Fat80y
Postby Fat80y » Fri Mar 11, 2022 11:43 am
Sorry was sick for a bit
Do I have the correct large bracket?
Also the throttle arm sees to pull from the left rather than the right?
Attached photos of pump:
https://www.dropbox.com/s/zcw1xjlj4cruo ... 0.jpg?dl=0
https://www.dropbox.com/s/3l8tl3h93tvqd ... 7.jpg?dl=0
https://www.dropbox.com/s/8a8vxmau9veyw ... 8.jpg?dl=0
Fat80y
Postby Chug » Sat Mar 12, 2022 11:05 am
0 460 414 150 is a pump fitted to Transits, the throttle arm looks correct but it seems to be missing the ball stud that he cable fits onto on the right hand side of the mechanism.
http://dieselcatalog.online/en/bosch/04 ... 14150.html
Chug
Postby Fat80y » Sun Mar 13, 2022 12:03 am
Thanks Chug.
That exploded diagram is fantastic.
Looks like I am also missing the control lever 388.
Anyone able to assist?
Diesel has hit $2.35 per litre, need to get back on veggie ASAP!
Fat80y
Postby Keef » Sun Mar 13, 2022 7:45 pm
Fat80y wrote:Diesel has hit $2.35 per litre, need to get back on veggie ASAP!
Think yourself lucky, diesel is over $3 in the UK!
Keef
Postby MinorMatt » Mon Mar 14, 2022 2:50 pm
I can definitely supply the other part of the bracket you need (new old stock genuine part) - £30 plus the postage, the operating arm looks like its all there to me (except for the ball - I can probably nick that from one of my knackered pumps)
93 L GL Minibus
Postby Fat80y » Wed Mar 16, 2022 12:00 am
Thanks Matt - would appreciate the ball - can you supply a pedal as well?
How do I pay? Paypal?
Fat80y
Postby MinorMatt » Wed Mar 16, 2022 9:53 am
I don't have a pedal at the moment - sorry
I found an old top lever bit with 2 of the balls on last night - its a bit manky but will do the job.
Won't go in the post until friday now though
Drop me a PM
93 L GL Minibus
