Single passenger seat in mk8
Re: Single passenger seat in mk8
Postby dumper » Sun May 16, 2021 7:04 am
I extended the floor in the front of mine even with it being a single seat model and then when I lowered the handbrake lever and cut down the cover it gave me something to screw it to .
Postby 16footgoose » Mon May 17, 2021 7:33 am
Digahole78 wrote:That great to hear. I posted my results after seeing a few vague posts saying it could be done but nothing that gave me full confidence. With regard to gap left in carpet, I have opted to extend ply floor from rear into that area as I'm doing a camper / work van conversion. Seems to have worked nicely. I left those studs on for now just in case I find a use for them but no doubt I'll cut them off at some point. If you come up with any nice designs for 3d printed covers please do share.
dumper wrote:I extended the floor in the front of mine even with it being a single seat model and then when I lowered the handbrake lever and cut down the cover it gave me something to screw it to .
Ah ok, yeah that makes a lot of sense I think. My Custom floor is lower than the cab area by a good couple of inches so I will have to get creative I think, possibly with a wooden board that goes over the electrical cables and then is held down with the now redundant extra seat base mounting hole.
2019 Transit Custom 2.0 EcoBlue SWB DIY camper
Instagram build: https://www.instagram.com/16footgoose
16footgoose
Postby Monkeyitch » Tue Jun 29, 2021 7:51 pm
Extending the floor into the cab area would look fab, but for the sake of access to the wires in the future I'm trying to source a factory floor / cab mat for the twin single setup. Does anyone know where to find these? They seem very hard to find, might need to visit the dealers.
Monkeyitch
Postby Billysven » Fri Jul 30, 2021 9:35 am
Hey Digahole
Did you manage to get a swivel for this seat. If so which one?
Great job btw
Bill
Billysven
Postby johnporter11 » Sun Aug 08, 2021 9:21 pm
I fitted the French one from Kiravans. Easy.
johnporter11
Postby BobBodd » Mon Nov 15, 2021 2:31 pm
A great post. Thanks all for content.
Thought I should add some thoughts/info. A year ago we converted our 350 double into a 'swivel'. The conversion was fiddly but not difficult. In addition to the kit I needed to add several shims to make the device perfectly flat.
It does work but as others have said is a pain as it relies on 4x sprung latches finding their homes in 4x holes each time it's used. Believe me this isn't easy but can be done. The difficulty exists because the 'pivot' is not fixed but floats over a large triangular area.
Long story short have now fitted a single drivers seat on passenger side with pivot.Ebay job. Was a little scruffy but releasing hog rings got covers removed and put though washing machine. Cleaned up well.
The M12 hole mentioned above doesn't require a tap BTW. The M12 bolts are thread forming and driving them in crushes not cuts a thread. It's what ford do. I managed it easily with a 1/2" ratchet.
Thanks for the thread.
BobBodd
Postby sidsilver2 » Tue Dec 14, 2021 9:29 am
Can this be done in a Transit Custom with heated seats?
sidsilver2
Postby Baldrick » Wed Dec 22, 2021 7:58 am
Hi.
Great thread. I'm about to follow in others footsteps.
Does anyone know will a Mk8 Panel van Drivers seat work as a replacement for the Mk8 Panel van dual seat. Obviously it needs the base quadrant thingy as well ?
Regards
Phill
Baldrick
Postby dumper » Wed Dec 22, 2021 8:42 am
Yes if it has a arm rest it will be on the wrong side my bus came with single seats but I removed them as it made it a lot easier to get my fat backside into the rear of the van I used a large flat washer to cover the holes up after removal you also have to swap the seat belt anchor over I’ve not had to do this part myself but from posts on here it can be done .
Postby Happe » Thu Mar 17, 2022 12:38 pm
This Post is great.
Looking for a Mk8 myself to convert and this information just saved me a lot of dosh I now can spend on other shiny things
Silver 98 semi high 80 2.5Di
Peugeot Boxer 2015 2.2L Puma driven
MY2017 Transit Mk8 350 RWD LWB High Roof 155PS in 'Not White'
Happe
Postby Blizz » Thu Mar 17, 2022 4:49 pm
dumper wrote:I removed them as it made it a lot easier to get my fat backside into the rear of the van I used a large flat washer to cover the holes up after removal you also have to swap the seat belt anchor over I’ve not had to do this part myself but from posts on here it can be done .
I'm searching for an armrest as my OEM single passenger seat hasn't one.
I guess you left the tilting mechanism inside the seat.
Would you sell the armrest?
Cheers,
David
Blizz
Postby dumper » Thu Mar 17, 2022 10:47 pm
Cheers,
David
Sorry m8 when or if I sell the van I will refit them .
Postby jb911964 » Fri Jul 21, 2023 3:25 pm
Hi, I'm struggling with the same problem, I want to change the double seat in my 2023 transit custom for a single seat. I have the seat but no seat box can't find a seat box for the passenger side anywhere. Did the drivers seat box fit straight in and did all the bolt holes line up ok?
Thanks in advance
Jim
jb911964
Postby Happe » Fri Jul 21, 2023 6:45 pm
jb911964 wrote:Hi, I'm struggling with the same problem, I want to change the double seat in my 2023 transit custom for a single seat. I have the seat but no seat box can't find a seat box for the passenger side anywhere. Did the drivers seat box fit straight in and did all the bolt holes line up ok?
Thanks in advance
Jim
Yes, fits straight in
Happe
Postby s1monsays » Wed Sep 24, 2025 2:37 pm
Thanks for providing the info/photos. Helped me realise it was a straight forward swap. :)
s1monsays
