Bonnet release
Bonnet release
Postby Captain chaos » Fri May 20, 2022 8:26 pm
Today I went to open the bonnet only to find there is no key hole , took the grill off and took some pics but definitely no key hole or lock
Any idea how I can open it so I can get a new mech for it
Captain chaos
Re: Bonnet release
Postby TheCake » Fri May 20, 2022 8:58 pm
if you can get a grinder/drill in there to carefully chew away at it until its free or worst case get a new bonnet and cut that section off to open it to gain access
is that rust spot new?
2010 mk7 t260 85 p.o.s. FWD, SWB
TheCake
Re: Bonnet release
Postby Captain chaos » Fri May 20, 2022 9:16 pm
hi, I'm not sure what part to remove or what part should turn. As I've never seen a good one I can't see what's missing. Can you show which bit I would need to remove? When it has a lock in it which bit does the lock turn?
Captain chaos
Re: Bonnet release
Postby Captain chaos » Fri May 20, 2022 9:37 pm
In this thread
viewtopic.php?f=2&t=132559
It says about drilling the lock and turn with a screw driver ...... But I have no lock lol so any suggestions?
Captain chaos
Re: Bonnet release
Postby TheCake » Fri May 20, 2022 9:48 pm
TheCake
Re: Bonnet release
Postby TheCake » Fri May 20, 2022 9:50 pm
The bonnet has a bar catch on it like this
TheCake
Re: Bonnet release
Postby Captain chaos » Fri May 20, 2022 9:52 pm
Is that the view from the top? So what am I missing and what part does the lock actually turn? If you take the lock off what do I have to move to release the catch?
Thanks for the picture at least I have some idea of what should be there when I open it
Captain chaos
Re: Bonnet release
Postby Captain chaos » Fri May 20, 2022 9:54 pm
Captain chaos
Re: Bonnet release
The round bit in the pic is inline with the hole in the grill
Captain chaos
Re: Bonnet release
Postby TheCake » Fri May 20, 2022 9:55 pm
if you look on ebay for a bonnet catch either mk6 2000-2006 or mk7 2006-2013 whichever model you have youll get a better look at mechanism
TheCake
Re: Bonnet release
Postby Captain chaos » Fri May 20, 2022 9:58 pm
Thanks ...... I did have a look but can't seem to relate it to what I have there as without a lock or a barrel it don't seem to make sense with just that plate and the split round bit with the hole in it
Captain chaos
Re: Bonnet release
Sorry, thought I said. It's a 2002 mk6
Captain chaos
Re: Bonnet release
Postby TheCake » Fri May 20, 2022 10:06 pm
thats the original barrel you should be able to drill that section out to access the mechanism behind
as worked out from images on this ebay listinghttps://www.ebay.com/itm/FORD-TRANSIT-M ... 2615781149
TheCake
Re: Bonnet release
Postby Captain chaos » Fri May 20, 2022 10:26 pm
Looking at this image
There is quite a complex piece of mech ....
On mine there is nothing there, just a square plate with that round part and nothing behind it
Captain chaos
Re: Bonnet release
Postby TheCake » Fri May 20, 2022 10:30 pm
the rest is behind the bodywork
TheCake
