IAT
Re: IAT
Postby metalworker0 » Thu Jun 02, 2022 2:52 pm
Well they work on resistance don't they, so anywhere in the circuit that has high resistance would make the software show very low temperature ..that would be fuses, wiring or a relay , corrosion where it screws in, if its a one wire type ..or even you using ptfe tape, or sealant on it .
All the best..mark
Re: IAT
Postby metalworker0 » Thu Jun 02, 2022 3:32 pm
I found this site that has a lot of information on testing the sensors
The site even the resistance values at different temperatures ...which may help you prove that your new one is also faulty
https://axleaddict.com/auto-repair/Inta ... ensor-Test
All the best.mark
Re: IAT
Postby walt1984 » Mon Jun 06, 2022 9:19 am
Thanks for info.
Mines part of the mass air flow.
It was changed for a hella version, I bought a cheap one to try and butcher up, then spent £100 on a decent one.
They all read the same.
Wirings fine with no breaks and multi plugs are clean.
If I shorted it out it reads -50c and a open circuit was something like +37c.
It's like it needs to re learn that 10c is 10c If that makes sense but I havnt a clue how to go about it.
Sent from my SM-A107F using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Re: IAT
Postby walt1984 » Fri Jun 06, 2025 2:03 pm
Just incase anyone has the same problem I've finally got to the bottom of it.
Been ignoring it and putting up with it for last few years but recently bought a low mileage 2014 custom that unfortunately had developed a starting problem.
Pratting about swapping things between custom and mk7 iv3 found out that there is a euro 4 and 5 mass air sensor.
My mk7 is a early euro5 with an identical engine, air box etc to the custom, when I put my reg in online it says the custom maf is not correct for the mk7.
Put a new custom maf in and the mk7 now starts as it should with out cycling the key and starts when warm without a fast idle or switching its heated screen on in the middle of summer. :D
walt1984
Re: IAT
Postby Altransit » Fri Jun 06, 2025 2:25 pm
Thanks for the update Walt :D
Users browsing this forum: Antuk, Google [Bot]
