Nkxtc wrote:Little update after AA looked at it with no luck and ended with a recovery now garage has it. Wasn’t the ignition switch as one was tried but no different. All fuses and earth wirings checked still nothing. Can’t connect a computer to it as no ignition. It’s now looking ominous and garage say could well be dash at fault. If so vans probably getting scrapped as not worth the cost due to Ford would need code it to van. Unless anyone any other ideas? Engine turns over still if remove relay R5 but not when it’s in. Won’t fire up but I presume with no ignition immobiliser not allowing it. Relay been tested it’s fine.
Has everyone stumped so far...
albhoy78 wrote:Hi there did the garage get the root of the problem?
Have the exact same diagnosis with my mk7
albhoy78 wrote:If you have the time could you send me what you have done,much appreciated I’m loosing the will to live trying to fix mine
Nkxtc wrote:PM me your number and il forward you a whatsapp of what worked for me
