ABS Pump bleeding
Re: ABS Pump bleeding
Postby ned » Tue Jul 05, 2022 4:52 pm
metalworker0 wrote:Don't know about professional, the eezibleed is aimed at DIY'ers, yet i found it one of the most effective gizmos i have . also cheap to buy (about £20) , although i only paid £1 from car boot sale 25 years ago...nothing to bust , nothing to wear out ..good tool 5 out of 5
These things
https://www.ebay.co.uk/itm/184633328443 ... SwSpBgDCJB
i bought and tried a couple of months back ..although they work (the vacuum pull is weak) 2 out of 5
..They are not as good as the eezibleed as that uses the pressure from your spare tyre...having tested it - i packed the tool away resorted back to eezibleed
I have one of those on the eBay listing, I found if you put Vaseline on the nipple it gets a better seal, think I had one of those ezibleed things back in the ‘90’s, if it’s the one I’m thinking it caps the brake fluid thingy on the vehicle then uses pressure from the spare.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby oot » Thu Jul 07, 2022 10:31 am
It should have been £1000, not £10000
MK7 (2008) 2.4dci Minibus
oot
Postby oot » Thu Jul 07, 2022 7:47 pm
I opted for a decent one from Sealey for £50 it seems very robust I will report back when I have used it
oot
Postby oot » Sun Jul 10, 2022 12:22 pm
I bled the brakes yesterday but there is still no pedal, so will have another go today, when it cools down, 26 C in Scotland!
The Sealey pressure bleeder works really well, solid bit of kit and worth the money
oot
Postby gsc1ugs » Thu Apr 25, 2024 1:18 pm
Ive never bled abs, what is procedure? I have Xtool D8 scanner at my disposal?
Thxs
gsc1ugs
Postby knobby1 » Thu Apr 25, 2024 9:28 pm
gsc1ugs wrote:Ive never bled abs, what is procedure? I have Xtool D8 scanner at my disposal?
Thxs
They're very expensive for what they do...well over $1100 aussie sheckles. It may be able to do the ABS bleed....you would hope so as that price.
You need Forscan which is "free" to download onto a windoze lappy.
Forscan is a very user friendly specialised Ford software and works very well with Transits, the recommended cables are reasonably cheap.
https://forscan.org/download.html
