by ray1965 » Sat Aug 06, 2022 9:51 am
i put them on my van, they are a genuine part, the rear of the sliding door one is obviously shoerter than the others, and one of them comes in 2 widths, cant remember which one, depending on van year, but tbh i dont think it matters (think its the fwd door one), as of note tho, look at the pictures on the net, they are slightly shorter than the window height but only noticeable if your looking for it
you will need a good cleaning agent that rots the 3m seals, (i used wynns brake cleaner) a blade and some wet and dry, time and patience to get rid of the old 3m tape
a lot of the ones on flea bay are damaged on the visible face for some reason, and they can get damaged removing them if the person doing so isnt careful, i ended up buying 6 to get 4
i used 20mm 3m scotch branded tape, i got that from a tape agent on flea bay, dont buy the cheap crap, its wierd tape lol, it dosnt stick to you, it relies on pressure when your fitting it, and the longer its stuck on the stronger it gets
