P2564-00 Boost Sensor
Postby Discofever » Tue Aug 09, 2022 7:25 pm
Evening all, my mk8 decided to blow the turbo last week, 148,000 on the clock, sounded like I’d ran over a crisp packet, so I’ve been out and replaced the complete turbo inc actuator, I’ve also replaced the oil feed pipe and return pipe. Now here’s the fault, cleared all the codes and it’s coming up with P2564-00 Turbocharger boost control position sensor circuit low- current DTC warning lamp on
When the engine is running the boost sensor is saying 1.7volts and if I unplug it it says 5volt, I’ve cleaned it but still nothing, the Boost Pressure Actuator Output sits at 0.00%, do you think the pressure sensor is naffed.
Thank you all as it’s now doing my head in.
Discofever
Re: P2564-00 Boost Sensor
Postby Discofever » Thu Aug 11, 2022 7:30 am
Morning all, so I’ve replaced the sensor and it’s still the same and I’m getting the same code, could be a wire failing to the sensor or turbo, here we go stripping that out.
Discofever
Postby Altransit » Thu Aug 11, 2022 9:55 am
Good luck, keep us posted :D
Postby Discofever » Mon Aug 15, 2022 2:07 pm
Well I’ve replaced the sensor and now I’m getting
“Turbocharger boost control position sensor “A” circuit low”
Any ideas people
Discofever
Postby Frag » Tue Aug 16, 2022 8:08 pm
That’s going to be a bad turbo actuator,or wiring to it.
Have you still got the old turbo or actuator ?
Where was the replacement unit from / what brand ?
Are you getting confused with the boost sensor ie MAP sensor ?
Frag
Ford Technician
Postby Discofever » Tue Aug 16, 2022 8:42 pm
At the minute it’s pointing to the new turbo, it’s a recon unit from a motor spares place as Ford wanted £150 more.
Discofever
Postby Robbieben » Mon Aug 22, 2022 1:10 pm
Do you have access to FORSCAN, you'll need it to calibrate the new turbo actuator to the engine ECU, thats likely where your problem is if it has not been done.
Robbieben
Postby Discofever » Mon Aug 22, 2022 4:23 pm
Thank you for that Robbie, I’ll give it a go
Discofever
Postby Discofever » Mon Aug 29, 2022 8:29 pm
Update, it was the actuator on the recon turbo, I took the van to a diesel specialist and they said it’s definitely the turbo actuator, I swapped the complete turbo and all is now good, well except for the van going into limp mode again, DPF was 212% full, one static regen later and all is good again
Discofever
