Masses of Mk3/4/5 parts - far too much to list
Re: Masses of Mk3/4/5 parts - far too much to list
Postby MinorMatt » Fri Apr 08, 2022 9:35 pm
Key numbers arn't recorded in the VIN
Good photos of the key will go (top.and side)
Postby Welsh sensei » Sat Apr 09, 2022 4:22 pm
OK will get photos to you tomorrow. To the forum or do you have an email address?
Welsh sensei
Postby MinorMatt » Sun Apr 10, 2022 4:38 pm
Postby Manchestermatt1986 » Tue Apr 19, 2022 11:19 am
Is there/do you have a bracket or anchor point for the mk4 rearcentre of the twin seat?
Manchestermatt1986
Postby MinorMatt » Tue Apr 19, 2022 12:25 pm
I am not sure to be honest - I will have a look later.
I may know someone who does though
Postby Manchestermatt1986 » Tue Apr 19, 2022 12:42 pm
Great. Also do you have the seat belt buckle and stalk to use on the centre belt please?
Manchestermatt1986
Postby Streakyjoe190 » Sun May 22, 2022 11:11 am
Hi, would you have good rear doors for my standard height mk3? Regards. Joe. 07712 441314
Streakyjoe190
Postby MinorMatt » Tue May 24, 2022 11:23 am
Streakyjoe190 wrote:Hi, would you have good rear doors for my standard height mk3? Regards. Joe. 07712 441314
What do you mean by standard height... there are 3 standard heights...
Postby sheltie » Fri May 27, 2022 8:13 pm
hi matt have you got a abs brake servo of a late model mk 5 255mm 1068574
sheltie
Postby MinorMatt » Mon May 30, 2022 8:42 am
sheltie wrote:hi matt have you got a abs brake servo of a late model mk 5 255mm 1068574
Unfortunately I don't
Postby crazylegskev » Thu Jul 14, 2022 2:29 pm
Hi, I am looking for a driverside rear door window seal. Some b*stard cut the window out. Also the plastic trim on the rear door handle opener on the inside. N267BOJ lwb high top. Got anything? Kev
crazylegskev
Postby MinorMatt » Mon Jul 25, 2022 9:11 am
I can't picture a plastic trim on a rear door handle?
I have lots of low roof rubbers, but no high top ones at the moment sorry
Postby Maltesefalcon » Tue Aug 30, 2022 10:43 am
Hi Do you have air conditioning pipes?
Maltesefalcon
Postby MinorMatt » Mon Sep 05, 2022 8:52 am
I have most aircon pipes... which ones do you need?
Postby Daveb1959 » Mon Sep 05, 2022 8:20 pm
Hi, would you have a spare wheel winch for a 1997 and if so whereabouts are you, thanks
Daveb1959
