Colin K wrote:Hello Guys,
Update Missed the two bolts that hold on the EGR pipe to the rear left hand side. Its off and can see a mark between the waterway and cylinder on piston 4 so result i hope.
Ebay now for a full head gasket set and bolts I wonder if there is any difference in quality?
That rear bolt on the EGR good heavens !!!!!!!
Col.
That rear bolt on the EGR good heavens !!!!!!! Col.
Colin K wrote:Hello Guys and Galls.
Update and HELP please. There is two cracks between the valves on two cylinders. You know she broke down due to the head gasket going that is really clear you can see the break in the old gasket..and I recon the cracks have been there since the cams exploded 20000 miles ago.
I dare nor rebuild her with the cracks there though I guess ??????
Lots of cylinder heads on ebay quite cheap for 2.2 models but not so many for the 2.4 Does anyone know if there is any difference please ....
Mine is a mk7 2.4 AF56VHT RWD must find out what euro she is Any help as always appreciated. Col.
Jim Archer wrote:If it's done a gasket and been leaking for a while, it will want both head and block skimming if you don't want it going again pretty damn quick like.
Jim
metalworker0 wrote:Jim Archer wrote:If it's done a gasket and been leaking for a while, it will want both head and block skimming if you don't want it going again pretty damn quick like.
Jim
his head is scrap ..if you read further up ...has cracks
Colin K wrote:Helo Guys,
Thank you for your advise. Well head is on all torqued up and cam cogs/chain on loose. Looking good. Still could not find a hole for the blooming injector pump so setting it like all of the you tube pics with the 6mm hole in the cog in line with that cover bolt @2 oclock position.
I put a steel rule over the block and it looks all true so I think it will be ok. All new bolts for the exhaust which was a joy good old screwfix
With luck should be turning the key at lunchtime tomorrow.
Cheers Col.
knobby1 wrote:Colin K wrote:Helo Guys,
Cheers Col.
TDCi pumps don't need " timing", so just fit the sprocket anywhere. Only the Mk6 TDDi needs timing up.
