Fuel line
Fuel line
Postby guzzi » Mon Sep 26, 2022 10:13 pm
Hallo @ all
We own a 1993 Laika motorhome Twin Wheel Axle Transit with 73Kw and i,m using the third lucas Fuel injection pump.
After the last pump chance i twisted the press fuel line on the Fuel injection pump as loosen the line.
After 1 turn i could loosen the line and after refitting it on the new pump it turned back and looked ok.
I didn't had problems for the next 20k miles.
A couple of weeks ago i had starting problems after a short break i wanted to start the engine but it wouldn't start, i tried it again and it started but
the engine light stayed on, i drove a few miles an as expected not faster as 40 mph, restarted again and everything was ok.
On the camp ground in Luxembourg i changed the Fuel injection pump. first ok but after 2 days same problem so the pump was not the problem.
There was a strong fuel smell so something was leaking, I think the twisted press fuel line on the pump is the problem.
Back home i asked the local Ford dealer if the could order the fuel line. He couldn't find the part and now i have a problem.
I have to make me a new fuel line, the plastic 8mm hose, the rubber rings and the bushing at he end wasn't a problem but the rubber ring holder is.
Does anyone knows if i can reuse this rubber ring holder or where i can order a new (or used) press fuel line from the fuel filter to the pump?
Any help, advice or suggestions gratefully received from anyone.
guzzi
Re: Fuel line
Postby MinorMatt » Wed Sep 28, 2022 9:05 am
When you say Lucas pipe, do you mean the lucas epic? The one with a large number of wires (19 iirc) going to a multi plug on the back?
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Re: Fuel line
Postby guzzi » Wed Sep 28, 2022 9:29 pm
Yes the DSA1096 with 19 pins connector.
I'm looking for the fuel line from the fuel filter to the lucas epic pump.
guzzi
Re: Fuel line
Postby Chug » Wed Sep 28, 2022 9:49 pm
If Matt hasn't got one I did have one from when I removed an epic pump and can have a look to see if I can locate it.
Chug
Re: Fuel line
Postby guzzi » Thu Sep 29, 2022 8:15 am
Thank you
guzzi
Re: Fuel line
Postby MinorMatt » Thu Sep 29, 2022 1:02 pm
I'm sure I will be able to find a good used fuel pipe from filter to pump.
2 x 2006 Mk7s
Re: Fuel line
Postby guzzi » Wed Oct 19, 2022 8:42 pm
Found something?
guzzi
