Kris’s Mk1 SWB Transit build (Hopefully PD powered)
Postby Krisdupreysgarage » Mon Oct 04, 2021 7:32 pm
Hi all
This is my latest purchase, a Mk1 SWB Transit
Plans are to make it into a sort of “Day van” for going to car shows in with the family, and for touring about in around the country.
No, it hasn’t been in a fire… the previous owner had it blasted then it was left outside so I’ll have a bit of work ahead to get the surface rust off. Otherwise though, it came from Malta, and seems to be solid in the right places!
I’ll update as I go on, unsure just yet when I’ll be starting, but hopefully make some progress soon!
Kris
No
Krisdupreysgarage
Re: Kris’s Mk1 SWB Transit build (Hopefully PD powered)
Postby Neil » Tue Oct 05, 2021 7:19 am
looks a challenge :D :D the malta climate has certainly helped keep a lot of mk 1 s considering most were 7 year old when they went
Neil v6
Neil
Postby oldskooler » Tue Nov 09, 2021 6:32 pm
great stuff kris,..will be an interesting project...
oldskooler
Postby Krisdupreysgarage » Tue Nov 09, 2021 6:35 pm
oldskooler wrote:great stuff kris,..will be an interesting project...
Cheers Declan!
I have acquired the engine/Loom/ECU etc, need to strip them out of the Mk4 golf at some point soon then make a start :)
Krisdupreysgarage
Postby Luke » Tue Nov 09, 2021 6:39 pm
PD will go well in that 8)
Postby PIO » Wed Dec 15, 2021 3:51 pm
Looking forward to seeing that Kris, will be cool..
PIO
Postby Krisdupreysgarage » Tue Mar 22, 2022 8:48 pm
Change of plan, no longer using a Mk4 golf, a friend donated this today and I will be stripping it shortly for everything useful! AWX engine code, PD130 with the engine the correct way round!
Hopefully making a start soon :)
Krisdupreysgarage
Postby waerhy » Fri Apr 01, 2022 9:37 pm
Looking forward to your progress :D
waerhy
Postby Krisdupreysgarage » Mon Oct 10, 2022 10:08 am
Intro video is now live! I plan to get the van lifted from storage in the next few weeks and get it to the workshop :)
https://www.youtube.com/watch?v=plbmM1E08sk
Thanks!
Krisdupreysgarage
Postby MinorMatt » Tue Oct 11, 2022 4:06 pm
unless you already have the V5c for it.... I would try and get it before spending too much time or money on it?
There have been a fair few challenges registering maltese vehicles recently
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby Krisdupreysgarage » Tue Oct 11, 2022 4:12 pm
MinorMatt wrote:unless you already have the V5c for it.... I would try and get it before spending too much time or money on it?
Matt, do you not need a valid MOT for importing?
Krisdupreysgarage
Postby MinorMatt » Tue Oct 11, 2022 4:14 pm
Thats a good point, I can't remember. Thinking about it you probably do (MOT on chassis no) - in which case you need to spend time and money on it!!
2 x 2006 Mk7s
Postby Krisdupreysgarage » Tue Oct 11, 2022 6:23 pm
Yea, when I imported my Mk2 Granada earlier this year I needed to MOT it on chassis number. Might be different with this as it’s exempt tho? I’ll check!
Kris
Krisdupreysgarage
Postby Krisdupreysgarage » Wed Oct 12, 2022 3:53 pm
So, I have now bought the gearbox to make the PD130 RWD.
VW Crafter 2012 gearbox, HVW9062605200 part number.
I already have the adaptor plate, now I need to try and find a good second hand DMF and clutch setup, and also a cable set to mount on the dash.
I lifted the Transit and brought it home, and had a good look around it. Video should be live this weekend!
Kris
Krisdupreysgarage
Postby MinorMatt » Mon Oct 17, 2022 2:41 pm
Kris
Ahhh forgot about that bit! I got an MOT exempt vehicle (1928 Morris) registered without an MOT. A club inspection identified that it was substantially complete but not in running order. Details were sent to DVLA and after they rejected it twice (having split it in to 2, obviously I had 2 rejections as each one had half the info missing!) I got an ID and logbook
2 x 2006 Mk7s
