NO POWER whatsoever without the key
Postby ford2233 » Wed Oct 12, 2022 8:53 am
Hi folks!
There is no power flaw whatsoever in my Transit until the key in the ignition is turned to 2nd position. Not even blinkers work without the key in 2nd position.
Do I have a fuses problem or does it sound like a major issue?
Thank you kindly for your time!
ford2233
Re: NO POWER whatsoever without the key
Postby knobby1 » Wed Oct 12, 2022 9:51 am
Sounds normal to me...ignition switch is a common issue when the "accessories" don't work withe the key in the 1st position.
Do your "Hazard" lights work..??
Postby ford2233 » Wed Oct 12, 2022 2:42 pm
knobby1 wrote:Sounds normal to me...ignition switch is a common issue when the "accessories" don't work withe the key in the 1st position.
Hi, and thank you for your reply. - Nothing works unless the key is inserted and turned to the 2nd position.
ford2233
Postby Altransit » Wed Oct 12, 2022 5:07 pm
Front battery dead?
What van is this :?
Postby ford2233 » Wed Oct 12, 2022 5:20 pm
Altransit wrote:Front battery dead?
What van is this :?
Ford Transit
Engine: 2.2 140hp, Diesel
Year model: 2011
The engine starts without any hesitation even now when there are freezing temperatures in the morning. I'll check the battery voltage tomorrow though. Thank you!
ford2233
Postby ford2233 » Thu Oct 13, 2022 2:25 pm
The battery is ok, showing 12,4V... Anybody any thoughts on what could be wrong? Does this have anything to do with fuses maybe? Thank you kindly for your time.
ford2233
Postby Altransit » Thu Oct 13, 2022 7:50 pm
Do you definitely only have one battery? RWD van will have two, some FWD will have two :)
Postby ford2233 » Fri Oct 14, 2022 5:06 pm
Altransit wrote:Do you definitely only have one battery? RWD van will have two, some FWD will have two :)
I have found the second battery and it's completely drained! My apologies, you all were right! Thank you guys once again for your time.
ford2233
