Perkins bits
Perkins bits
Postby rangie76 » Wed Oct 05, 2022 12:11 pm
Hi does any one know to any bell housings for the gearbox to suit the 4.108 engine fitted to transit also Perkins air pump .
Many Thanks.
rangie76
Re: Perkins bits
Postby Neil » Sun Oct 09, 2022 9:15 am
is it the same as the early v4 petrol ??
Neil v6
Neil
Re: Perkins bits
Postby rangie76 » Sun Oct 09, 2022 5:01 pm
I am not familiar with what the v4 used did the v4 have a rear facing starter motor slung up the side of the gearbox instead of lying along length of the sump/block ? I think that set up is only relevant to a perkins engine setup.
rangie76
Re: Perkins bits
Postby Neil » Sun Oct 09, 2022 6:10 pm
rangie76 wrote:I am not familiar with what the v4 used did the v4 have a rear facing starter motor slung up the side of the gearbox instead of lying along length of the sump/block ? I think that set up is only relevant to a perkins engine setup.
not sure , but i have an early ford dealer workshop manual and it has chapters on the engine variants 4108 , 499 and petrol 1.7 and 2.0
Neil v6
Neil
Re: Perkins bits
Postby Neil » Mon Oct 10, 2022 7:06 am
and the book only has info on one gearbox
Neil v6
Neil
Re: Perkins bits
Postby rangie76 » Mon Oct 10, 2022 3:42 pm
HI, The gearbox is the same but the bell housing is different and instead of cable clutch I think its hydraulic I have tried to upload a picture of one but I doesn't seem to want to do it its off another post on mk1 / 2 transits under different gearbox types.
rangie76
Re: Perkins bits
Postby Ralph.9 » Tue Oct 11, 2022 6:42 am
The early Perkins gearboxes are differnt, the clutch is rod operated & diesel bellhousing has different bolt spacing to the gearbox.
Ralph.9
Re: Perkins bits
Postby rangie76 » Wed Oct 12, 2022 5:25 pm
Thanks Ralph, I must admit I have not worked on mk1 transits before so not familiar, just to clarify the perkins bell housing will not fit on later mk1 gearbox ? Thanks
rangie76
Re: Perkins bits
Postby Neil » Wed Oct 12, 2022 6:09 pm
the bellhousing should fit on the gearbox , the bolt position to the engine might be differant looking from the front is your starter on the right ,, or passenger side ?
Neil v6
Neil
Re: Perkins bits
Postby rangie76 » Wed Oct 12, 2022 8:58 pm
Hi Neil, the tranny was converted from a perkins to a pinto engine and box changed so thats why I cant tell you what I have , it should be on passenger side but facing rearwards from engine along side of the gearbox.
rangie76
Re: Perkins bits
Postby Chug » Wed Oct 12, 2022 9:27 pm
Chug
Re: Perkins bits
Postby Neil » Thu Oct 13, 2022 6:58 am
rangie76 wrote:Hi Neil, the tranny was converted from a perkins to a pinto engine and box changed so thats why I cant tell you what I have , it should be on passenger side but facing rearwards from engine along side of the gearbox.
ok , i only have info on 499 4108 and v4 modals sorry
Neil v6
Neil
Re: Perkins bits
Postby rangie76 » Thu Oct 13, 2022 10:12 am
that is the photo of the box yes , well done Chug I could not get it to upload . The transit did originally have a 4.108 as you have stated in your list .
rangie76
Return to Mk 1 & 2
