abs pump
abs pump
Postby lockiejohn » Tue Oct 18, 2022 5:48 pm
will any abs fit my transit its a euro5 engine
lockiejohn
Re: abs pump
Postby knobby1 » Tue Oct 18, 2022 7:56 pm
lockiejohn wrote:will any abs fit my transit its a euro5 engine
No, just find one with the same part number.
They rarely fail, what are your symptoms.??
Re: abs pump
Postby lockiejohn » Tue Nov 01, 2022 9:33 am
had pump changed but now traction control light on but showing no faults
lockiejohn
Re: abs pump
Postby Frag » Tue Nov 01, 2022 11:28 am
Has it had the steering angle sensor etc calibrated since fitted ?
Frag
Ford Technician
Re: abs pump
Postby knobby1 » Tue Nov 01, 2022 9:31 pm
lockiejohn wrote:had pump changed but now traction control light on but showing no faults
If the T/C light is on...the "WILL" be a fault code stored. What code reader are you using.??
Re: abs pump
Postby lockiejohn » Sat Nov 05, 2022 12:53 pm
garage did the pump
lockiejohn
Re: abs pump
Postby knobby1 » Sun Nov 06, 2022 8:44 pm
lockiejohn wrote:garage did the pump
You need to find out what the actual fault code/s is/are..?? Guessing and throwing parts at it is a waste of your time and money.
