poor dash lights
poor dash lights
Postby samsonv18 » Mon Jul 19, 2021 7:05 am
first time on in a long time ,still got my mk3 looking at changing the dash lights to leds
only some look like they are one peace so need new holders any one knows the best place to find them
can find the small ones but not the big ones
samsonv18
Re: poor dash lights
Postby bortaf » Mon Jul 19, 2021 2:32 pm
Any ford of that era and earlyer uses them capless 501 or T10
https://www.ebay.co.uk/itm/303562338622 ... %3A2334524
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby samsonv18 » Thu Feb 17, 2022 5:57 pm
thank you nice one
samsonv18
Postby diverobin » Mon Oct 31, 2022 12:57 pm
My dash lights are all very dim. Can you give me a pointer as to hot to get to them to replace the bulbs? Thanks
diverobin
Postby dumper » Mon Oct 31, 2022 4:00 pm
Just unscrew the cluster unclip the wires and speedo cable if earlier type is the easiest way take the top off the column cowl should be no need to remove the steering wheel but is easier with it off .
Postby diverobin » Mon Oct 31, 2022 7:22 pm
Ok, cheers
diverobin
Postby V184 » Tue Nov 01, 2022 2:57 pm
if you turn the lights on you can get your head where the pedals are & see behind the dash you can change them without removing anything :wink:
V184
Postby dumper » Tue Nov 01, 2022 5:21 pm
V184 wrote:if you turn the lights on you can get your head where the pedals are & see behind the dash you can change them without removing anything :wink:
Yes it’s not to bad that way as well
Postby diverobin » Wed Nov 02, 2022 12:02 pm
Ah, cool. I'll try that!
diverobin
Postby diverobin » Sat Nov 05, 2022 3:18 pm
So I replaced all the dash bulbs with new ones, like for like. All working but still dim. Any ideas? Could it be just dirt and grime behind the instruments?
diverobin
Postby dumper » Sat Nov 05, 2022 11:02 pm
Now this may not apply to a mk3 but on a mk2 I had one with poor dash lights that had a blue lens that the bulbs shone through and the heat form the bulbs discoloured and turned them brittle what I did was remove them and instead of a blue light it gave a brighter light not sure if I had to strip the cluster to take the lens out
Postby bortaf » Sun Nov 06, 2022 1:36 am
dumper wrote:Now this may not apply to a mk3 but on a mk2 I had one with poor dash lights that had a blue lens that the bulbs shone through and the heat form the bulbs discoloured and turned them brittle what I did was remove them and instead of a blue light it gave a brighter light not sure if I had to strip the cluster to take the lens out
That's usually the issue, the covers go brown with heat, remove the covers and fit green LEDs in there, or blue if you prefer ?
you have to strip the cluster as the covers come out into the cluster :)
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby diverobin » Sun Nov 06, 2022 8:13 am
Ok, thanks guys. I'll have a go at that. As usual, this forum is a fount of knowledge!
diverobin
Postby dumper » Mon Nov 07, 2022 6:54 am
Yes leds would be a very good modern move when I did the mk2 probably not been invented :D
Postby V184 » Mon Nov 07, 2022 5:11 pm
dumper wrote:Yes leds would be a very good modern move when I did the mk2 probably not been invented :D
Probably give you arc eye :lol: :lol: :lol:
V184
