New member plus mk5 transit problem
Postby Cozy2 » Wed Dec 07, 2022 11:36 pm
Hi everyone im cozy2 thanks for allowing to join .I have a mk5 transit which I converted into a motorcaravan owned now for 4 years living in it fulltime working on the Rd. I have refitted New propshaft New brakes New wheel bearings New inner outer sills no expense stared to keep on rd using origanal parts . But come across a problem was going down motoway 5 month over 7 month ago and the engine comely cut out so was towed to location so I could fix was told it was my fuel stop solenoid but couldn't get one so checked online and it turned out to be the imobiliser as the code above on roof was giving the code as engine wouldn't turn over nothing so got it going by bypassing the wire from fuel solonoid to battery worked but then alternator went so changed this New one charging but now 7 month down the Rd it's not charging but when breakdown came out they tested and everything OK but driving on a night time 3 week ago I lost all power and I'm baffled to what it could be as it turns over but won't start put new battery in to please help thanks
Cozy2
Re: New member plus mk5 transit problem
Postby dumper » Thu Dec 08, 2022 7:24 am
Welcome mate what’s the exact model and engine of your van .
Postby Cozy2 » Thu Dec 08, 2022 11:48 am
It's a p reg with a 2.5di banana engine I believe it's the lwb 1997
Cozy2
Postby V184 » Thu Dec 08, 2022 12:10 pm
Timing belt ok ? getting fuel to injectors ?
V184
Postby Cozy2 » Thu Dec 08, 2022 2:00 pm
Yea fuel getting through will start but when driving the battery going dead sometimes it charges as had new alternator new starter but since imoboliser stuck on and bypassed this it's started doing this I'm no expert and maybe a easy fix other wise engine is great when running thanks for reply
Cozy2
Postby Noctule » Thu Dec 08, 2022 3:37 pm
It might be worth fitting a voltmeter so you can keep an eye on what the alternator is putting out as you drive.
A potential fault is the ignition switch. When you lose battery power you lose juice to the fuel solenoid and headlights, but does it also lose power to things like the side lights and accessory socket? If not then the ignition switch may be the cause.
2012 Mk7 125t350 camper conversion in progress
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 190 HiCube DRW self-built camper
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby V184 » Thu Dec 08, 2022 7:20 pm
Cozy2 wrote:Yea fuel getting through will start but when driving the battery going dead sometimes it charges as had new alternator new starter but since imoboliser stuck on and bypassed this it's started doing this I'm no expert and maybe a easy fix other wise engine is great when running thanks for reply
Sorry i read it as - what it could be as it turns over but won't start
V184
Postby Bruce e » Sun Dec 11, 2022 10:19 pm
Just because it is a new alternator does not mean it is not faulty
Sent from my SM-G390Y using Tapatalk
Bruce e
Postby gotgcoalman » Wed Dec 21, 2022 11:19 pm
Must have got sorted
Not been back on since the 8th.
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
