Mk7 transit thermostat
Postby Sandas02 » Tue Dec 20, 2022 11:03 am
Hi can anyone help i have just took the 3 torque screws out the thermostat housing and when i pulled the thermostat out a spring on its own came out along with a plastic spacer and fell on the floor im now not sure if it goes thermostat spring then bush or thermostat bush then spring can anyone help
Sandas02
Re: Mk7 transit thermostat
Postby knobby1 » Tue Dec 20, 2022 8:18 pm
Sandas02 wrote:Hi can anyone help i have just took the 3 torque screws out the thermostat housing and when i pulled the thermostat out a spring on its own came out along with a plastic spacer and fell on the floor im now not sure if it goes thermostat spring then bush or thermostat bush then spring can anyone help
Euro4 or Euro-5..?? 2.2, 2.4 or 3.2..??...or is it a 2.3 petrol engine..?? You've not told us what you have. If the spring has come out, the thermostat is broken and will need replaced.
Euro-4 2.4 here..:
https://www.catcar.info/ford/?lang=en&l ... M2MjYrMTMz
2.2 should be similar.
