Transit Mk7 attempted theft *something stuck in ignition*
Postby crowlands27 » Wed Dec 28, 2022 11:35 am
Someone tried to steal my Mk7 transit last night and what looks like a drill bit is lodged in the barrel and snapped. I've found it near impossible to remove. Any suggestions? *EDIT* 2011 plate
crowlands27
Re: Transit Mk7 attempted theft *something stuck in ignition
Postby tranmx2 » Wed Dec 28, 2022 12:19 pm
Easier to work on it when out of location. Likely a new barrel is needed. The electric connections are at the other end.
Other posts re' key, barrel, electrics on the forum.
Better to know the year, emissions, VIN etc of the vehicle.
tranmx2
Postby crowlands27 » Wed Dec 28, 2022 12:23 pm
tranmx2 wrote:Easier to work on it when out of location. Likely a new barrel is needed. The electric connections are at the other end.
It's 2011 and I've added pics if that helps.
How would I remove the barrel if I can't get the ignition to rotate? Thanks
crowlands27
Postby fortyeight » Wed Dec 28, 2022 12:33 pm
arn,t they b------s
fortyeight
Postby tranmx2 » Wed Dec 28, 2022 2:15 pm
Don't know.
Seems from this image that there is a brass plunger that needs to be moved and there is a spring washer on the end.
If the brass plunger cannot be moved I'd likely grind away the end to get at the drill bit (if that's what it is) so as to turn it anti clockwise.
There are picks for sale so it could be the left over of a pick.
There could be info' on this or another forum as to how to go about it.
tranmx2
Postby metalworker0 » Wed Dec 28, 2022 2:58 pm
Dirty rotten ?+?+/+/#
only advice is put one of these on .......as a deterrent
you could even make something that looks like one
if they see one of these ...i dont think they will bother ..they will pass and head for the next van
these are just thoughts ..wont heklp you now ..but could help yopu in the future.
this i bought for £3.50 from a car boot sale ..its an old halfords one and built like a brick outhouse
Postby eskimodoodle » Wed Dec 28, 2022 5:52 pm
yes best to always put a steering lock and a pedal lock on vans .
Tip: remember to put the key side of steering lock away backwards as otherwise they can just drill the key hole on steering lock .
eskimodoodle
Postby metalworker0 » Wed Dec 28, 2022 6:02 pm
eskimodoodle wrote:yes best to always put a steering lock and a pedal lock on vans .
Good idea ..will see if i can fit it that way next time.
all the best..mark
Postby M3Stig » Wed Dec 28, 2022 7:44 pm
whats the wiring have they tried to by pass?
M3Stig
Postby TheCake » Wed Dec 28, 2022 9:22 pm
looks like they tried to screwdriver it or possibly tried a key the may have made from door barrel then when it snapped tried to drill it out.
not sure if the barrels are similar enough in transits but you may be able to rebuild a new barrel to fit your key if you are able to extract the pins (was able to do this with my fathers vivaro)
is that rust spot new?
2010 mk7 t260 85 p.o.s. FWD, SWB
TheCake
Postby TheCake » Wed Dec 28, 2022 9:24 pm
come to think of it those are gouges from needle nose pliers so a failed attempt at extracting their ''key''
TheCake
