EGR valve bolt access
Re: EGR valve bolt access
Postby knobby1 » Thu Feb 02, 2023 1:24 am
matts09transit wrote:Installed it successfully (except a couple coolant leaks at the ends but should be easy enough to fix). Thanks everyone!
Hearing a whistling when driving which I assume is the turbo - only whistles at higher revs. Something to be concerned about?
Check all your boost hoses and intercooler for splits.
Postby fisjon » Sun Feb 05, 2023 3:26 pm
knobby1 wrote:
fisjon wrote:Is it supposed to do this every time?
Yes. Each time the ignition is cycled on/engine start/off, the EGR valve goes through a self clean cycle, sounds like a small hacksaw for a couple of seconds.
Humm, I don't think it is doing that at the moment :(
fisjon
Postby knobby1 » Sun Feb 05, 2023 8:40 pm
It may be "munted"... :mrgreen:
