Scanner advice please
Postby fisjon » Thu Jan 12, 2023 1:37 pm
Hi
2014 2.2 transit custom campervan
The van currently has a problem with the DPF and a faulty/stuffed up EGR valve.
It is going into the garage for a Terra Clean + diagnostics next Wednesday.
The van only gets short journeys most of the time but does some long journeys in the summer.
The handbook says that you can initiate a DPF clean but I can't seem to work out how this is done as when I follow the procedure nothing happens.
I am slowly learning about the DPF system and it appears that some scanners allow you to initiate a DPF clean.
I am looking for advice on the best scanner/s that will do this job.
all help welcome, thanks in advance
john
fisjon
Re: Scanner advice please
Postby Chug » Thu Jan 12, 2023 2:53 pm
A laptop and Forscan with a ELM 327 is good.
Get one of these Modified ELM 327 from Steve Elmer @ Tunnel Rat Electronics here
https://tunnelrat-electronics.fwscart.c ... 45457.aspx
Then download and Install Forscan here
https://forscan.org/download.html
Chug
Postby fisjon » Sun Jan 29, 2023 4:00 pm
Hi guys,
Bought an iCarsoft CR Pro+ as I need to access several vehicles.
Fixed my daughters VW Transporter after plugging in the scanner (faulty Maf sensor).
As for my van, took it in for a terra clean and all seems to be going well. Plugged in the scanner and there are no codes at the moment.
fisjon
Postby knobby1 » Sun Jan 29, 2023 8:20 pm
fisjon wrote:Hi guys,
Does your van currently have any fault lights on..?? Some scanners don't cope with the Transit protocols well....which is why we recommend the use of Forscan and a modified ELM-327, we know they work.
Postby mallood » Tue Jan 31, 2023 5:33 pm
tunnelrat's ELM is the way to go like Knobby said, contacted many obd sellers before i bought this ELM, and they all werent 100% certain it would run on my Transit....this one does!!
mallood
Postby fisjon » Sun Feb 05, 2023 3:24 pm
Hi Lord Knobrot,
No, there are no fault lights on or codes at the moment, the iCarsoft scanner seems to be able to function ok on the transit custom and certainly reads a lot more info than my previous generic code reader.
I'm still learning how to get the best out of it so work in progress
cheers
john
fisjon
Postby knobby1 » Sun Feb 05, 2023 8:34 pm
fisjon wrote:Hi Lord Knobrot,
cheers
john
You don't have to have a fault light on to have a fault code/s stored. As mentioned, some scanners don't cope with the Transit protocols well...and some can give incorrect codes or miss them altogether. We've learnt over the years what works and what doesn't.
Postby dewalt22 » Thu Feb 23, 2023 5:49 pm
Ive just purchased a Tunnel rat, looking forward to using it.
dewalt22
