Tourneo Custom window pattern templates?
Postby Karina_T » Fri Jan 20, 2023 12:22 pm
Hi all,
I'm trying to source thermal blackout screens for my Tourneo Custom 2018 with tailgate and finding it surprisingly difficult.
I have seen these ones but I'm not convinced they're that thick or insulating...
https://www.ebay.co.uk/itm/275510262419 ... R5LIo8W4YQ
Insulation wise, I'd love the Brunner ones which are a bit more rigid but obviously more bulky:
https://www.youtube.com/watch?v=-qD6IUp ... l=Kiravans
Harrison trim supplies have this:
https://www.harrisonstrimsupplies.co.uk ... n-material
Which is basically what I had in my old T4. My question is, has anyone sourced Tourneo Custom window patterns that I can print out to make my own screens up?
I've looked everywhere but can't find any online - I bet they're there, hidden away in a corner under the bed of the internet...
Ford Tourneo Custom 2.0 310 EcoBlue Titanium 128bhp 284.00 torque Independence RS model
Karina_T
Re: Tourneo Custom window pattern templates?
Postby Karina_T » Fri Jan 20, 2023 12:53 pm
Aha....
Answering my own query.
These may be helpful to outher Tourneo owner/converters...
https://www.vector-templates.com/templa ... _swb/8062/
Off to spend some money...
Karina_T
Postby Karina_T » Fri Jan 20, 2023 1:24 pm
Forget that - appears to be just the outside of the vehicle. Not the internal specs....
Karina_T
Postby johnporter11 » Fri Jan 20, 2023 5:53 pm
I believe I have a better approach to this.
https://www.ebay.co.uk/itm/374198538595
I use 10mm semi-rigid closed-cell foam, hand cut to fit precisely within window frames. Black finish on the glass side for stealth, carpet on the inside (reflectix can be added to the glass side for summer radiant heat reflection if required). No messy unreliable suckers. Total blackout. Excellent insulation. Because they fit close against the glass, very little air gets behind to condense.
johnporter11
Postby Karina_T » Sat Feb 04, 2023 3:32 pm
Hey Johnporter11 - Nice result. But in the end I've found that Campal do the thermal screen ones - but using the thicker 7 layer material.
I've ordered a full set but I really do like the look of your solution.
Karina_T
Postby johnporter11 » Sat Feb 04, 2023 8:22 pm
Let me know how you get on with them please.
johnporter11
Postby Karina_T » Mon Feb 06, 2023 1:41 pm
johnporter11 wrote:Let me know how you get on with them please.
Will do John,
They've just arrived and look to be well made/finished and not too bulky.
I'm only just starting out on my 'part time camper' conversion so it may be a while before I actually spend the night in the new bus but I'll try to update this once I have!
Karina_T
Postby Darraghmcl » Mon Feb 20, 2023 11:03 pm
Hey John
How much to supply a full set for a Tourneo Custom please? Would that include front windows also?
Darragh
Darraghmcl
cron
