Mk2 Transit, 2L pinto poor fuel economy, won't accelerate...
Postby jckm2000 » Fri Apr 21, 2023 4:54 pm
... without choke.
Hi Folks,
I've got a 2l pinto with a weber 34 ich fitted to my mk2 swb motorhome.
Starts fine, engine purrs nicely but it hesitates on acceleration with choke fully in. Give it a smidge of choke and it pulls ok. Cruises ok without choke.
Also I'm only getting 12mpg!
I've done the seals on the servo and renewed all vac hoses. Distributor vac is good. So is oil breather. Checked for air leaks on manifold etc. Timing set to 8°.
New jets (165 main, 50 idle, 190 air
corrector), diaphragm, float and gaskets on carb. Compression is good.
Any ideas what's going on?
Not looking for stella mpg but 12's a bit low!
Any ideas?
MK1 V4 flatbed (long gone)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Re: Mk2 Transit, 2L pinto poor fuel economy, won't accelerat
Postby Mr twin choke » Fri Apr 21, 2023 6:58 pm
Have you taken the spark plugs out for a look yet? The colour and condition of them can tell you a lot about how the air/fuel mixture is burning and maybe point you in the right direction. Is it running on electronic ignition or points?
Mr twin choke
Postby jckm2000 » Fri Apr 21, 2023 7:38 pm
Hi Mr Twin Choke,
Well, it's a bit hard to tell because I keep having to pull the choke out. Currently they're a bit sooty near the base but whiteish at the electrodes.
Electronic ignition. 29mm weber 34ich
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby Mr twin choke » Fri Apr 21, 2023 8:24 pm
I'd be tempted to give them a clean and try running it with no choke for a while (if you can stand it). That way you'll be able to see better how it's burning. Could be accelerator pump diaphragm has a small leak even if it is new. I've seen plenty faulty new parts over the years
Mr twin choke
Postby ace_098 » Sat Apr 22, 2023 10:34 am
jckm2000 wrote:Starts fine, engine purrs nicely but it hesitates on acceleration with choke fully in. Give it a smidge of choke and it pulls ok. Cruises ok without choke.
Hi everyone, I'm new to this forum.
The quoted part (if I quoted correctly) suggests running lean and possibly a punctured membrane (can't remember which).
Happened on my K10 Micra with a Solex twin barrel.
Floor it without choke it just sorta hums in agony, pull 0,5cm of choke and it takes off. With that membrane punctured I spent 14L of petrol in 80km, on a 1.0L engine lol.
ace_098
Postby dumper » Sat Apr 22, 2023 12:42 pm
Is the accelerator pump working with the air filter off engine not running if you operate the throttle you should see fuel squirting into the venture also have you checked that the float level is within the settings if shutting off to early so the level in the float chamber is low it can weaken the mixture .the only other problem I’ve had with Webber carbs is worn throttle spindles.
Postby bortaf » Sat Apr 22, 2023 7:12 pm
sounds like classic holed/rotted acc pump diaphram as dumper says :?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby fortyeight » Thu May 11, 2023 8:54 am
have you checked the air filter,also the intake make sure there's no birds nest to be found in it
fortyeight
Postby fortyeight » Thu May 11, 2023 12:26 pm
sorry to the last post im forgetting its got a weber carb not the vv
fortyeight
Return to Mk 1 & 2
