Cylinder head bolt tightening order
Postby davew2 » Mon May 22, 2023 8:45 pm
Hi could someone please put a picture of the head bolt tightening order on a 2.5 di please i've searched everywhere and cannot find one. I know the torque setting sequence 70nm 70nm then 90 degree. Thanks
If it ain't got leaf springs it in't a commercial
davew2
Re: Cylinder head bolt tightening order
Postby dumper » Mon May 22, 2023 9:06 pm
Just start from the middle bolts first and then work your way out going diagonally each side till you get to each end and then start in the centre and do it again unless it’s the torque first and then the required amount of degrees
Postby Chug » Mon May 22, 2023 10:21 pm
yes diagonally from the centre, if you search online many' vehicles are the same
example here https://www.rtsauto.com/wp-content/uplo ... quence.jpg
Chug
Postby MinorMatt » Tue May 23, 2023 8:46 am
They say diagonal... I say spiral out :)
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby Altransit » Tue May 23, 2023 8:48 am
MinorMatt wrote:They say diagonal... I say spiral out :)
That's the way that I was taught :mrgreen:
Postby davew2 » Tue May 23, 2023 11:53 am
I actually found one
davew2
Postby MinorMatt » Tue May 23, 2023 11:56 am
it spirals out :)
2 x 2006 Mk7s
Postby gotgcoalman » Tue May 23, 2023 5:44 pm
davew2 wrote:I actually found one
Found it's twin.
And the undoing bit
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby gotgcoalman » Tue May 23, 2023 6:44 pm
Don't forget one of these.
Or mark the head bolts with tippex for the 90degree bit.
Seem to remember bolts at the back are a bit awkward
gotgcoalman
Postby dumper » Tue May 23, 2023 8:43 pm
As long as you start in the middle and work your way out diagonally or spiral works ok
Postby V184 » Tue May 23, 2023 9:29 pm
gotgcoalman wrote:Don't forget one of these.
105ibft from memory never had any problems :wink:
V184
Postby dumper » Tue May 23, 2023 10:53 pm
Torque setting only we always then did them again when hot or after a run the advantage of torque and then tighten to the degrees method was you did them only once no re torque
