Prep work before fitting wood cladding
Postby poindexter » Sun Jun 11, 2023 6:16 pm
Hey Forum, I am at a critical stage of my campervan conversion project and looking for some advice here please.
I have insulated with spray foam and now would like to proceed with cladding the walls with tongue and groove wooden cladding. I have installed the wooden framework to attach the cladding to but am a little concerned about moisture.
It would be very difficult to create a moisture barrier with the tongue and groove. It is definitely what I want however.
Just looking for general advice really on what I should do in preparation for fitting the cladding? I did think that I could put in a 3mm ply underlay and seal it around the edges but that would be a fair bit of extra work, cost and weight on a Transit Jumbo.
The van is well ventilated with two floor vents, a spinning vent on top, two skylights and two roof vents.
Should my ventilation be good enough that I don't need to worry so much about airborne moisture or should I do some extra prep work? If so are there any good suggestions that are faster, cheaper and lighter than what I had in mind?
Appreciate your responses...
poindexter
Re: Prep work before fitting wood cladding
Postby bortaf » Sun Jun 11, 2023 10:44 pm
if it's closed cell foam then it's technicly a vapour barrier itself :? if it's the normal builder stuff in a can it's probably open cell so not really a sealed layer ?
i've just used polythene vapour control barrier from screwfix or wicks ect, you can use silver backed bubble wrap but it's a waste of money IMHO ? TBH there's 2 ways of tackling it, let it breath or seal it, if you don't use a barrier make sure it's vented top and bottom of the wall :?
AS you say lots of ventilation is more important but it never hurts to go the belt and braces route :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby dumper » Mon Jun 12, 2023 6:30 am
On all the camper’s I’ve built never used a vapour barrier all I’ve done is waxoil the body panels then used the recycled plastic bottle insulation foam and with lined ply wood with carpet to finish.I built a mk3 this way and later upgraded to a mk5 transferring the conversion into it and the insulation was as goofy as the day I fitted it .
