This cranksensor we've been talking about can't be a Hall sensor. It's 2-pins.the CPS here is a Hall sensor,
And I've just looked up an example "Inductive sensor" (I thought so)
Just a permanent magnet with coil solenoid. You know like they use on mopeds, scooters & chainsaws. It just makes a +ve & -ve voltage spike sgnal when a metal edge goes past it.
The problem with these is the tiny wire inside can detach when hot (prove it with Ohm meter test)
Other problem prone to is when covered in metal dust the signal output is lower than normal - which is no big deal when engine running because the metal edge goes past fast enough to induce the +/- pulse, but when the edge goes past slow (starting) there's not enough induction. I would had thought the PCM would throw a MIL warning light on instrument if that was to happen. And definately so if the wire inside detached.
