No coil light, no crank
Postby Harryca » Fri Jul 28, 2023 10:11 am
Hi all,
Occasionally when trying to start my mk7 2.4 tdci the coil light doesn’t come on when I turn the ignition on. When it doesn’t come on the van doesn’t crank. If I turn the key 5 or 6 times between the off position and the ignition position the coil light eventually comes on and the van will crank and start. There are no codes showing associated with this.
Any suggestions what I could start looking for?
Cheers,
Harry.
Harryca
Re: No coil light, no crank
Postby knobby1 » Fri Jul 28, 2023 9:56 pm
Harryca wrote:Hi all,
Cheers,
Harry.
Sounds like your ignition switch is not well...quite a common issue with the Mk6/7 Transits.
Cheap and easy to replace to rule it out.
Postby Harryca » Sat Jul 29, 2023 9:52 am
Cheers,
Harry.
It’s a brand new switch. That was my first thought!
Harryca
Postby knobby1 » Sat Jul 29, 2023 10:03 pm
Ah...you never mentioned you had replaced the ignition switch.
Possibly a poor earth, there's a multitude of earths on the transits, you need to check them all.
Postby Jim Archer » Tue Aug 01, 2023 2:01 pm
Was it doing this before the new switch? Assume you mean the contactor unit rather than lock body?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Harryca » Tue Aug 01, 2023 10:45 pm
Jim Archer wrote:Was it doing this before the new switch? Assume you mean the contactor unit rather than lock body?
Jim
I can’t say it was. The unit (not the lock) was replaced by a mechanic at the same time as the scv to try and fix an issue with it cutting out (which is still causing me a nightmare but that’s another issue). I have another brand new one in a box that I might try and fit but I can’t see it making any difference considering there’s already a new one on there.
Cheers,
Harry.
Harryca
Postby knobby1 » Wed Aug 02, 2023 12:53 am
Jim
Cheers,
Harry.
When the SCV was replaced...were the learns done..??
Postby Harryca » Wed Aug 02, 2023 8:37 am
A fuel pump learn was done, but I’ve since done the injector pilot and fuel pump learns again (Prv counter reset wouldn’t work in forscan) and the cutting out is now worse and I have an error code telling me to do a fuel pump learn. I’m thinking I’m just going to have to replace the PRV and SCV and do the learns again from scratch to rule out any issues. I’m getting a massive sudden spike in the actual fuel pressure which is followed by the van cutting out immediately.
Cheers,
Harry.
Harryca
Postby knobby1 » Wed Aug 02, 2023 8:02 pm
Harryca wrote:
A fuel pump learn was done, but I’ve since done the injector pilot and fuel pump learns again (Prv counter reset wouldn’t work in forscan) and the cutting out is now worse and I have an error code telling me to do a fuel pump learn. I’m thinking I’m just going to have to replace the PRV and SCV and do the learns again from scratch to rule out any issues. I’m getting a massive sudden spike in the actual fuel pressure which is followed by the van cutting out immediately.Cheers,Harry.
Were the SCV & PRV genuine Ford/Denso items..?? If not genuine, we've found they either cause the engine to fail to start after fitting, struggle to pass the learns or fail soon after.
Postby Harryca » Wed Aug 02, 2023 10:33 pm
SCV was a denso item, PRV was tested and worked so wasn’t replaced. Fuel pump learn was completed so it clearly wasn’t causing too many issues and the SCV must have been working. For the cutting out issue I’m wondering whether to replace both Prv and scv with new genuine ones or just replace the Prv, and obviously do the learns again. I’m still scratching my head as to how I didn’t have any fault codes relating to this issue, I re-did the learns just to see if it made any improvement, they both completed first time without issue, and now I have a code telling me to do a fuel pump learn. What is that about?
Still no closer to figuring out the coil light no start issue either.
Cheers,
Harry.
Harryca
Postby knobby1 » Thu Aug 03, 2023 12:55 am
Harryca wrote:
Cheers,
Harry.
How was the PRV tested..?? They're just a simple relief valve...but will hold silly amount of pressure, at least 1600 bar or 23,206psi, they either work or they don't. A simple check is to pop the PRV return line off and see if there's any fuel flow @ idle, it can be wet but no dripping or flow...or pull it out of the fuel rail and see if it's in pieces. If the PRV is blown, the engine will never start.
Cutting out at traffic lights or junctions and/or hunting idle out is usually the SCV causing it, the piston often sticks in the bore causing hysteresis and hence a hunting idle or cutting out due to too low a fuel flow.
Postby Harryca » Thu Aug 03, 2023 10:44 am
Disconnected from the plastic connector and van cranked, no fuel came out. It hasnt been taken out to see if it’s in pieces but the van starts fine. I did have hunting at idle but that stopped after the SCV was changed, but it still cuts out. It used to cut out and the revs would drop off instantly out but just about hang in there, all the dash lights would come on and after about 2-3 seconds you could drive it normally again without having to turn the key, but now it properly cuts out - the engine actually stops. I lose power steering and it’s caught me in some real tricky situations a couple of times, almost crashing into road barriers doing 50mph with no steering and having to pump the break pedal. Can’t drive the van anymore like that so need to get it sorted. But if it’s already had a brand new DENSO SCV at a cost of over £200 for the part alone, is another new one going to sort it?
Cheers,
Harry.
Harryca
Postby Harryca » Tue Sep 23, 2025 8:07 pm
Finally, after a long time I’ve finally found the issue. I hope I’m not speaking too soon, but so I seem to have resolved the starting issue, as well as the cutting out issue I was having (different post - will also update that).
I found a very slightly corroded pin on a relay, and it didn’t seem to be making good contact. Specifically the glow plug relay at the very top of the engine bay fuse box. With the engine running, I could wiggle it and the engine would cut out. If I pulled the relay out, the coil light wouldn’t come on when turning the ignition on, and there would be no crank. Cleaned this up and bent the leg slightly so it made better contact. So far so good, coil light comes on every time, van starts as normal, hasn’t cut out once.
Harryca
Postby knobby1 » Tue Sep 23, 2025 8:14 pm
Harryca wrote:Finally, after a long time I’ve finally found the issue. I hope I’m not speaking too soon, but so I seem to have resolved the starting issue, as well as the cutting out issue I was having (different post - will also update that).
Strange...they don't need glow plugs to start...I pulled my glow plug relay out years ago and have had no issues starting. Also a Mk7 2.4.
