Harryca wrote:Hi all,
Occasionally when trying to start my mk7 2.4 tdci the coil light doesn’t come on when I turn the ignition on. When it doesn’t come on the van doesn’t crank. If I turn the key 5 or 6 times between the off position and the ignition position the coil light eventually comes on and the van will crank and start. There are no codes showing associated with this.
Any suggestions what I could start looking for?
Cheers,
Harry.
knobby1 wrote:Harryca wrote:Hi all,
Cheers,
Harry.
Sounds like your ignition switch is not well...quite a common issue with the Mk6/7 Transits.
Cheap and easy to replace to rule it out.
Jim Archer wrote:Was it doing this before the new switch? Assume you mean the contactor unit rather than lock body?
Jim
Harryca wrote:Jim Archer wrote:Was it doing this before the new switch? Assume you mean the contactor unit rather than lock body?
Jim
I can’t say it was. The unit (not the lock) was replaced by a mechanic at the same time as the scv to try and fix an issue with it cutting out (which is still causing me a nightmare but that’s another issue). I have another brand new one in a box that I might try and fit but I can’t see it making any difference considering there’s already a new one on there.
Cheers,
Harry.
knobby1 wrote:
When the SCV was replaced...were the learns done..??
A fuel pump learn was done, but I’ve since done the injector pilot and fuel pump learns again (Prv counter reset wouldn’t work in forscan) and the cutting out is now worse and I have an error code telling me to do a fuel pump learn. I’m thinking I’m just going to have to replace the PRV and SCV and do the learns again from scratch to rule out any issues. I’m getting a massive sudden spike in the actual fuel pressure which is followed by the van cutting out immediately.Cheers,Harry.
knobby1 wrote:
Were the SCV & PRV genuine Ford/Denso items..?? If not genuine, we've found they either cause the engine to fail to start after fitting, struggle to pass the learns or fail soon after.
SCV was a denso item, PRV was tested and worked so wasn’t replaced. Fuel pump learn was completed so it clearly wasn’t causing too many issues and the SCV must have been working. For the cutting out issue I’m wondering whether to replace both Prv and scv with new genuine ones or just replace the Prv, and obviously do the learns again. I’m still scratching my head as to how I didn’t have any fault codes relating to this issue, I re-did the learns just to see if it made any improvement, they both completed first time without issue, and now I have a code telling me to do a fuel pump learn. What is that about?
Still no closer to figuring out the coil light no start issue either.
Cheers,
Harry.
knobby1 wrote:
How was the PRV tested..?? They're just a simple relief valve...but will hold silly amount of pressure, at least 1600 bar or 23,206psi, they either work or they don't. A simple check is to pop the PRV return line off and see if there's any fuel flow @ idle, it can be wet but no dripping or flow...or pull it out of the fuel rail and see if it's in pieces. If the PRV is blown, the engine will never start.
Cutting out at traffic lights or junctions and/or hunting idle out is usually the SCV causing it, the piston often sticks in the bore causing hysteresis and hence a hunting idle or cutting out due to too low a fuel flow.
Harryca wrote:Finally, after a long time I’ve finally found the issue. I hope I’m not speaking too soon, but so I seem to have resolved the starting issue, as well as the cutting out issue I was having (different post - will also update that).
I found a very slightly corroded pin on a relay, and it didn’t seem to be making good contact. Specifically the glow plug relay at the very top of the engine bay fuse box. With the engine running, I could wiggle it and the engine would cut out. If I pulled the relay out, the coil light wouldn’t come on when turning the ignition on, and there would be no crank. Cleaned this up and bent the leg slightly so it made better contact. So far so good, coil light comes on every time, van starts as normal, hasn’t cut out once.
