Recommendations please
Postby ColinJack » Fri Sep 01, 2023 3:52 pm
Looking for a recommendation for someone in Norfolk/Suffolk with facilities to replace king-pins in our Mk3 van.
Just failed MOT for too much play! Was fine last MOT - 2,500 miles ago. :x
I don’t have either the tools (reamer etc.) or experience to do it. Need an old hand pro with a decent garage, ideally reasonably local.
Any suggestions please?
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Re: Recommendations please
Postby Altransit » Fri Sep 01, 2023 3:57 pm
You may know this already, but whenever my kingpin equipped vans were due for MOT, I used to fill them, immediately before, with the thickest grease that I could lay my hands on :)
When I did have to have them changed, it was always a massive problem getting anyone with the tools to do it :?
Postby ColinJack » Fri Sep 01, 2023 4:01 pm
Altransit wrote:You may know this already, but whenever my kingpin equipped vans were due for MOT, I used to fill them, immediately before, with the thickest grease that I could lay my hands on :)
Yeah - I have got away with pumping full of grease for 10 years but suddenly got a picky MOT guy.
Need an old hand that knows how to do it and has the tools.
ColinJack
Postby gotgcoalman » Fri Sep 01, 2023 4:45 pm
Trying to swing a BIG hammer in the wheel arch to tap the old ones out was always an issue
Done em on a MK2 and a MK3 many years ago.
One person heating with a torch and another bashing away.
Was it "play" or "lift" they got you on?
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby dumper » Fri Sep 01, 2023 4:56 pm
What did they actually fail it on was it lift or rock when I was presenting hgvs for test on some models if you removed the bushes in the stub axle they would still be within the limits to pass the test they used to fail easier on kingpin lift.there are different limits for kingpin’s based on wheel diameter.they may have failed it on just feel and not on the limit in the tester’s manual.
if it was mine I would show me on what limits they have failed it on.
For removing the kingpins as gotchman says that’s the way to get them out on my mk3 at home I used heat and a hydraulic bearing puller.
Postby ColinJack » Fri Sep 01, 2023 4:58 pm
gotgcoalman wrote:Trying to swing a BIG hammer in the wheel arch to tap the old ones out was always an issue
Play.
Nightmare ... I have a new set of QH but need someone to put them in without f* them up!
Every garage I have spoken to doesn't even understand what I'm talking about.
Some older owners have said dropping the axle out and doing them on the bench is the easiest.
ColinJack
Postby ColinJack » Fri Sep 01, 2023 5:01 pm
dumper wrote:What did they actually fail it on was it lift or rock when I was presenting hgvs for test on some models if you removed the bushes in the stub axle they would still be within the limits to pass the test they used to fail easier on kingpin lift.there are different limits for kingpin’s based on wheel diameter.they may have failed it on just feel and not on the limit in the tester’s manual.
Was a temporary tester whilst usual guy was on holiday so can't even ask that. b*stard!
ColinJack
Postby dumper » Fri Sep 01, 2023 5:05 pm
Fitting the new bushes will need to be reamered if who fits them are not carful they could end up with more play then when you started when I did mine at home I didn’t have access to a reamer and had to take the stub axles to machine shop to get them done .
Postby dumper » Fri Sep 01, 2023 5:07 pm
Take it back talk to the usual tester when he’s back off Hoiday.
Postby gotgcoalman » Fri Sep 01, 2023 5:13 pm
dumper wrote:Take it back talk to the usual tester when he’s back off Hoiday.
gotgcoalman
Postby ColinJack » Fri Sep 01, 2023 7:14 pm
Tried that today and apparently he came back from holiday and resigned! :roll:
ColinJack
Postby Altransit » Fri Sep 01, 2023 8:27 pm
Aww bu99er :roll: Maybe he heard that you were coming back for a re-test :mrgreen: :P
I can remember taking my old Sherpa to 4 different testing stations to find a tester who knew what kingpins were, and understood that they all have a bit of play :roll:
Postby ColinJack » Fri Sep 01, 2023 8:49 pm
Nasty business. His brother was killed in a bad smash whilst he was away and he came back and said he didn’t want anything to do with cars ever again. Horrible.
ColinJack
Postby gotgcoalman » Fri Sep 01, 2023 9:18 pm
are there any Council run Mot places near you?
they dont do repair work,but will give an honest opinion of any work that needs doing.
gotgcoalman
Postby ColinJack » Sat Sep 02, 2023 10:03 am
gotgcoalman wrote:are there any Council run Mot places near you?
Going to get another opinion this week.
ColinJack
