Mk7 clutch
Mk7 clutch
Postby steviebee » Sun Oct 01, 2023 5:35 pm
Afternoon everyone. I have a problem with the clutch on my van. 2012 2.2 fwd 6 speed 125 bhp. When l let the clutch up nothing seems to happen for an inch or so also feels very soft then van lurches forward slightly. No problem getting gears very smooth and behaves after that initial pull away. New clutch master cylinder fitted as the arm was worn but made no difference. Thanks for any advice.
2005 85ps t280 swb camper, chrome door handles, outside temp gauge and clock and auxiliary 12volt socket. Colour coded bumpers & door mirrors, Mondeo glasses holder. Auto dim rear view mirror. Vantunered :D . 2012 Transit Trend in Panther Black
steviebee
Re: Mk7 clutch
Postby andz327 » Sun Oct 01, 2023 10:31 pm
Has the problem only been since master cylinder change???
andz327
Re: Mk7 clutch
Postby steviebee » Mon Oct 02, 2023 7:56 am
andz327 wrote:Has the problem only been since master cylinder change???
No it was there before and as the small nylon/plastic rod in the master cylinder was worn thought it was that .
steviebee
Re: Mk7 clutch
Postby steviebee » Mon Oct 02, 2023 12:19 pm
Just been out to the van again. tried the clutch without engaging a gear. First inch or so felt soft then is was as though it jumped. Every depression of the cutch pedal after that felt good.
steviebee
Re: Mk7 clutch
Postby steviebee » Sat Oct 07, 2023 11:22 am
Found problem it was the Lower gearbox mounting. New one fitted all good now. Just shows you l had the lower gearbox mountain go on my Mk6 and it was juddering when pulling away. This was totally different.
steviebee
Re: Mk7 clutch
Postby knobby1 » Sun Oct 08, 2023 8:25 pm
steviebee wrote:Found problem it was the Lower gearbox mounting. New one fitted all good now. Just shows you l had the lower gearbox mountain go on my Mk6 and it was juddering when pulling away. This was totally different.
Lower gearbox mount shouldn't affect the clutch at all...there's no mechanical connection and they aren't cable operated.... :? I'm confused.
Re: Mk7 clutch
Postby steviebee » Mon Oct 09, 2023 12:19 pm
Me as well your Lordliness. Pesky transit gremlins. Perhaps it was me not used to the clutch and just assumed it was the clutch. Still all good now, hopefully.
Steve.
steviebee
