ROCKER COVER GASKETS FOR MK5 SMILEY??
Postby 97transit2.5D » Wed Nov 08, 2023 1:22 am
Hiya
ANYONE JUST DONE THIS JOB AND where do we get one from??
thks
97transit2.5D
Re: ROCKER COVER GASKETS FOR MK5 SMILEY??
Postby MinorMatt » Wed Nov 08, 2023 11:13 am
Any motor factor will supply one.
I've had mine off many times. Just make sure the cover isn't domed around the bolt holes from overtorquing, and do the bolts to spec, starting in the middle and working out in a spiral.
Postby 97transit2.5D » Wed Nov 08, 2023 8:41 pm
where does we get the gasket from. surely its not red silicon rtv type...got any brands that are good on ebay or like?
97transit2.5D
Postby MinorMatt » Thu Nov 09, 2023 11:30 am
As above - any motor factor will have/get one. Normal brands
Postby MinorMatt » Thu Nov 09, 2023 11:31 am
Here is the first one I spotted on eblag
https://www.ebay.co.uk/itm/225357199096 ... R6Dalbr2Yg
Postby 97transit2.5D » Mon Nov 13, 2023 7:35 am
THKS minoMATT I APPRECIATE THE INFO, I think the gaskets are the same from 1994-2000.
mines a 1999 engine transplant from a ldv convoy. I see they all have nine holes .
BGA or british gasket company looks like cork???
others
look like rubber or silicon???
97transit2.5D
Postby MinorMatt » Mon Nov 13, 2023 10:53 am
There are cork ones (mk3) or rubber around a steel inner (91 onwards) either are good.
Postby V184 » Mon Nov 13, 2023 8:43 pm
97transit2.5D wrote:THKS minoMATT I APPRECIATE THE INFO, I think the gaskets are the same from 1994-2000.
others
the one in the picture is the later reusable one, if a cork one has been used it can bend the cover because the bolts are 6mm against the early 8mm ones & trying to revert to the one in the later one can cause oil leak Best to replace like for like
V184
