Cheap but effective insulation/soundproofing ideas please!
Re: Cheap but effective insulation/soundproofing ideas pleas
Postby sherwoodcycles » Fri Dec 01, 2023 11:23 pm
Cheap, then cover anything metal in artificial lead flashing. I've done it to all the vans I've owned. It will peel off the roof though. For the roof, get some proper sound deadening sticky stuff.
This kills the vibration well for the cheapness
Greeny
sherwoodcycles
Postby snowjoe » Sat Dec 02, 2023 12:03 pm
Nifty, thanks!
I may try some of this stuff -https://www.ebay.co.uk/itm/374329580447
Cheap and it's butyl, so I wouldnt be surprised if it's at least 80% as good as the pricey stuff, if not 100%
2009 MK7 Crew Bus, soon to be a 'camper' hopefully, so I can keep up with tosspots on bicycles
snowjoe
Postby sherwoodcycles » Sun Dec 03, 2023 1:15 am
5mm is very thick. See if you can buy it thinner and hopefully you will get twice the coverage.
I even used loft insulation in my early days. Very good until you start getting itchy eyes
Greeny
sherwoodcycles
Postby dumper » Mon Dec 04, 2023 7:47 am
sherwoodcycles wrote:5mm is very thick. See if you can buy it thinner and hopefully you will get twice the coverage.
Know what you mean that’s why the recycled bottle type is good not itchy at all .
Postby sherwoodcycles » Fri Dec 08, 2023 11:05 pm
The plastic recycled stuff is great for insulation (heat) but I found it did almost nothing to sound. But it is user friendly.
Greeny
sherwoodcycles
Postby animemontt » Thu Dec 21, 2023 2:51 pm
The proper carpet is the 4 way stretchable from suppliers like Magnum motorhomes .Yes the cheap foam backed.
animemontt
Postby bortaf » Sat Dec 30, 2023 11:47 pm
i use sticky backed closed cell foam on the metal surfaces, it does a bit of both, noise reduction and insulation, then i used plastic bottle insulation over in places where it would fit, you can rip it in half if you need thinner, did my connect last year and it made a lot of differance, especialy when i sleep in the back :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
