OBD reader!?
OBD reader!?
Postby Tragustauro » Mon Dec 11, 2023 11:08 pm
For an old car/Truck like mine. Do anybody know which type of OBD reader I should invest in.
I know (if I´m correct) that the OBD-2 are for newer cars and is probably not working on a car from 1995.
TT.
FORD TRANSIT 100S VAN H-D 2,0 DOHC 115 HP
FORD TRANSIT Box (E_ _) 2.0 (EAL, EAS)
Engine Code NFS-Petrol.
Model year1990 (RR94) Reg. date 06-10-1995
Tragustauro
Re: OBD reader!?
Postby MinorMatt » Tue Dec 12, 2023 8:45 am
Yours is a petrol?
You may well find it is OBD compliant. If not your best guess is forscan software (free for phone or laptop) with one of their recommended adaptors. Can't guarantee it will work, but it will (apparently) read diesel of the same age.
Re: OBD reader!?
Postby Tragustauro » Tue Dec 12, 2023 11:00 pm
@ MinorMatt
Ohh interesting!!
Yes it is a petrol.
It is called "forscan software"?... I just checked it out.
Not even sure how to figure this one out. Don`t know where and how it looks on my car.
And what it is even called on my car to find the adapters I assume it is so old now that it is not being used anymore... I will investigate..
I thank you!
TT
Tragustauro
Re: OBD reader!?
Postby MinorMatt » Wed Dec 13, 2023 2:08 pm
Have a look here
https://forscan.org/home.html
The connector for the diagnostics is in the fuse box. The socket uses the spare fuse holder as a lid
Re: OBD reader!?
Postby Tragustauro » Thu Dec 14, 2023 12:29 am
Hello.
Holy smokes!!
There is a lot to go thru!
A lot of "new" stuff to understand.
I will spend some time to see what I need for my type of car.
Thank again for your input.
TT.
Tragustauro
Re: OBD reader!?
Postby Tragustauro » Sun Dec 17, 2023 2:37 pm
Hello.
Would you say that this is the OBD "plug" reader connection?
I assume I need to get an adapter to be able to use a OBD reader!?
TT.
Tragustauro
