Battery 'drain' hose - is it important?
Postby snowjoe » Mon Jan 08, 2024 3:33 pm
I just changed the battery in our MK7 crew bus. It's the wrong way around for the 'drain' (breather?) hose to attach, it's on the wrong side now.
I have never paid much attention to these hoses, but as it's a family bus I thought I'd ask!
Can i just forget about it, or should I try to find some kind of extension to make it fit into the battery?
2009 MK7 Crew Bus, soon to be a 'camper' hopefully, so I can keep up with tosspots on bicycles
snowjoe
Re: Battery 'drain' hose - is it important?
Postby Altransit » Mon Jan 08, 2024 3:49 pm
All of the batteries that I've fitted in recent years have a vent attachment on both sides. You just remove the blanking plug and fit it in the opposite side.
It's not a great idea to not fit the drain hose, which vents the gases to the outside, and you definitely shouldn't charge the battery with the plugs in place.
Postby dumper » Mon Jan 08, 2024 4:54 pm
Definitely needs the vent to the outside you don’t want explosive gases building up in the seatbox
Postby snowjoe » Mon Jan 08, 2024 5:34 pm
Thanks both of you, so I need some sort of extension hose. No idea where to find one (or what to search for!) but will have a dig around
snowjoe
Postby metalworker0 » Mon Jan 08, 2024 5:53 pm
first place i would look is an aquarium shop ,,, air pipe - cheap and will probably do the job .
note; i know motorcycle batteries have this stuff as a breather ..car batteries may be the same of larger.
all the best,.mark
Postby snowjoe » Mon Jan 08, 2024 5:54 pm
handy, thanks
snowjoe
Postby andz327 » Thu Jan 11, 2024 12:23 am
Windscreen washer hose is cheap out of The RANGE
andz327
Postby snowjoe » Thu Jan 11, 2024 2:17 pm
thanks
snowjoe
