MK5 SMILEY steering wheel removal ??? how??
Postby 97transit2.5D » Tue Jan 09, 2024 5:33 am
Steering wheel column is one central splined threaded post.
But no twin holes for steering removal kit. What do you use....sledgehammer? there is nothing to lever on under it as you would
damage to security system, wiper and light stalks.
or the bang it on all four corners trick and then yank it wards
YES have added oil to spline
or use hammer under it .
All of these came from You tube, but cant find anyone doing it for mk5 smileys
97transit2.5D
Re: MK5 SMILEY steering wheel removal ??? how??
Postby 97transit2.5D » Tue Jan 09, 2024 6:41 am
got it to work...hammered central spline with nut slightly above threads of spline to protect it, and then pulled up with knees
WORKED.
added lithium grease
note arrow on spline with original direction and replaced
97transit2.5D
Postby dumper » Tue Jan 09, 2024 8:01 am
Glad you got it usually I put the nut back on a few threads so the wheel doesn’t come off and hit you and pull and wobble the wheel like a deranged monkey till it comes off had a problem on a truck once that this didn’t work so got a big gorilla to remove it :lol:
Postby MinorMatt » Tue Jan 09, 2024 8:57 am
I undo the nut and then hammer one side, then the other using fists or wobble it.
Always comes off.
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby gotgcoalman » Thu Jan 18, 2024 11:03 pm
I get Matt to do mine
Too bloody quiet :shock:
gotgcoalman
