What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Wed Jan 10, 2024 8:05 pm
ned wrote:
loot wrote:
Altransit wrote:You need Mk6/7 wheel nuts for alloys, vans with factory alloys had them as standard.
You can't use the flat nuts with alloys :(
You can, the aftermarket alloys for mk7 are flat washer type that use standard mk7 nuts. The custom wheels have tapered ones but the taper is not very wide. I'm thinking of getting a set of custom/mk8 studs and fit them. 14 x 1.5 and then the custom alloy nuts will fit. It's an unnecessary complication created by Ford I think.
Or you could just buy the correct pitch taper alloy wheel nuts, I’m sure somewhere on here there’s a link for them on the bay of e
Those are nasty though they flake and rust quickly and I don't feel 100% safe that the threads won't fall off :lol:
07 350 170ps
Ids map here
loot
Postby ned » Wed Jan 10, 2024 8:18 pm
loot wrote:
ned wrote:
loot"quote="Altransit wrote:You need Mk6/7 wheel nuts for alloys, vans with factory alloys had them as standard.
Those are nasty though they flake and rust quickly and I don't feel 100% safe that the threads won't fall off :lol:[/quote]
Aye, but if only you know someone, an engineer type, with a big shed and a lathe that could fabricate some, that would be perfect or change all the hubs to mk8/custom hubs, anyway that’s all boring, the big question is what diesel V8 are you gonna drop in there with 2 turbos and 500nm torque
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Wed Jan 10, 2024 8:27 pm
ned wrote:
loot wrote:[qute="ned"]
Aye, but if only you know someone, an engineer type, with a big shed and a lathe that could fabricate some, that would be perfect or change all the hubs to mk8/custom hubs, anyway that’s all boring, the big question is what diesel V8 are you gonna drop in there with 2 turbos and 500nm torque[/quote]
I will just buy 20 transit custom studs and the stainless covered nuts that are standard,i actually like them. The studs just Knock out.
I've seen some build info.
4.27 diff, I wanted 3.73.
Manual air conditioning though :o
The engine I can get remapped and as its swb with 3.73 diff will be strong enough,it'll wheel spin like foof i reckon.
Need to source low roof or pop top, and side door number 2 panels.need a tourneo to chop up
07 350 170ps
Ids map here
loot
Postby Altransit » Sat Jan 13, 2024 11:19 pm
I've finally sorted out the intermittent (will it, won't it turn over) starting problem, which I thought was the starter motor ..........................
Turns out that it was the rear battery, with a new one installed, it's now starting every time. I'm still confused as to why it was intermittent, cos after a few attempts, it would turn over properly, and fire up :?
So we'll see what happens :roll:
Postby Airthies » Sun Jan 14, 2024 1:46 am
Altransit wrote:I've finally sorted out the intermittent (will it, won't it turn over) starting problem, which I thought was the starter motor ..........................
Heard of loose connections in the battery fuse box,
Might be worth checking all the clamp nuts in there
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Jan 14, 2024 10:09 am
Anyone used lanoguard? I was thinking of cleaning underneath the new van,and welding it all then oil based paint then shutz. But does lanoguard act like rust killer?
07 350 170ps
Ids map here
loot
Postby Whitters » Sat Jan 20, 2024 6:04 pm
Put the new batteries in it, and tried to move it, but the clutch pedal seems to be sticking to the floor - is this a common occurrence? To be fair the van hasn't been moved since September when it passed it's MOT, but I'm unsure whether it'll be the master cylinder, slave cylinder or clutch itself... Anyone have any ideas?
Also, how do I know whther it has a dual mass flywheel or not?
It's an 05 Mk6 17-seat minibus (2.4 - RWD) that I'm converting into a camper.
Whitters
Postby loot » Sun Jan 21, 2024 7:18 pm
Guys, I have bought the extended Rear bumper, does anyone know if the Reinforcement bar behind is bigger too?
07 350 170ps
Ids map here
loot
Postby Airthies » Sun Jan 21, 2024 7:43 pm
loot wrote:Guys, I have bought the extended Rear bumper, does anyone know if the Reinforcement bar behind is bigger too?
Yes it is.
Though an engineer of your calibre should be able to make it work with the original by the ingenious use of hedge treasure
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Jan 21, 2024 8:22 pm
Yes it is.
I found a picture of 1 online.
I could make something but I'm trying to see if there's I can buy. Also want a detachable tow bar.
07 350 170ps
Ids map here
loot
Postby Airthies » Sun Jan 21, 2024 9:08 pm
loot wrote:
Yes it is.
Got a spare parking sensor module if you want one
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Jan 21, 2024 9:22 pm
Airthies wrote:
loot wrote:
Airthies wrote:[qote="loot"]Guys, I have bought the extended Rear bumper, does anyone know if the Reinforcement bar behind is bigger too?
Yes it is.
Sent using crapatalk[/quote]
I just got a bumper from b parts and they also include the mounting brackets which hopefully aren't rotate mine.
I've never had reverse sensors lol. Any good?
07 350 170ps
Ids map here
loot
Postby Airthies » Sun Jan 21, 2024 9:24 pm
loot wrote:
Airthies wrote:
loot wrote:[quote="Airthies"][qote="loot"]Guys, I have bought the extended Rear bumper, does anyone know if the Reinforcement bar behind is bigger too?
Yes it is.
I've never had reverse sensors lol. Any good?[/quote]Don't know
Never got round fitting them to my first van (or her van as she's got a camera) or replacing the two that weren't working on my current van
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Redvee » Mon Jan 22, 2024 12:48 am
Sorted the screenwash that reached the bottom inch of the windscreen. Pulled the pipe off the back of the bonnet and pulled it through and blew down the pipe and heard the screenwash bubbling so knew the pipe was clear. Connected it all back up and the jest reached the middle of the screen so it seems there was some crud in the washer bottle/pipe.
Redvee
Postby Airthies » Mon Jan 22, 2024 1:04 am
Redvee wrote:Sorted the screenwash that reached the bottom inch of the windscreen. Pulled the pipe off the back of the bonnet and pulled it through and blew down the pipe and heard the screenwash bubbling so knew the pipe was clear. Connected it all back up and the jest reached the middle of the screen so it seems there was some crud in the washer bottle/pipe.
Likely the bottle will be full of algae type gunk that'll float back to the washer pump filter screen.
Better off pulling the motor out of the bottle and flushing it out properly.
V86+patch
V86.04
X-Prog
C81
Airthies
