Is the pinto motor mount bracket and rubber of the mk2 inte
Postby McRowney » Tue Feb 20, 2024 11:41 pm
Sorry if this has already been mentioned on the forum, but my search has been fruitless.
thanks
McRowney
Re: Is the pinto motor mount bracket and rubber of the mk2 i
Postby McRowney » Tue Feb 20, 2024 11:48 pm
Sorry for the mess, I don't know how delete this double topic
McRowney
Postby Altransit » Tue Feb 20, 2024 11:56 pm
McRowney wrote:Sorry for the mess, I don't know how delete this double topic
Not to worry, I'll sort it 8)
Postby McRowney » Wed Feb 21, 2024 12:26 am
sorry again
I wanted to title the topic as: "Is the pinto motor mount bracket and rubber of the mk2 Is interchangeable with mk3?"
McRowney
Postby Altransit » Wed Feb 21, 2024 1:11 am
You can only use a certain amount of characters in the topic title, so it needs to be shorter and attention grabbing, and then you can put the full question in the post.
I can change it if you want me to, but I can't make it longer than the maximum.
Postby McRowney » Thu Feb 22, 2024 12:05 am
Thanks, Altransit
I would like to rewrite the title as " Are mk2 and mk3 engine bracket interchangeable?"
would this work?
(I'll try to see if it works in the mk3 topic :mrgreen: )
McRowney
Postby Altransit » Fri Feb 23, 2024 1:50 pm
Return to Mk 1 & 2
