I have to change the timing belt again.
The last time, 8 years ago, I removed the pulley from the crankshaft. To do this, you have to loosen the 36 mm bolt (330 nm tightening torque).
Now I wanna ask if anyone in the forum has fitted the timing belt to an MK2 with a 2.5DI diesel engine without removing the pulley.
Last time I was worried about having to bend the new timing belt too much to get it round the corner of the oil pump housing.
Here are a few pictures from the last time when I did the timing belt so you can see what I mean:
Do you guys always remove the pulley when doing the timing belt
Ii's just that I don't want to damage the new timing belt right away during installation.
Thanks,
Pete
